Zwift & Cell Phones: Your recommendation
Getting close to replacing my Samsung Galaxy S-8 Plus. It runs Zwift pretty well, unlike my new Windows laptop.
My main beef is battery power, I am limited to about 2.5-3 hours on Zwift.
What would be some solid phone choices (non-Apple) for Zwifting.
Thank you.
http://www.fitspeek.com the Fraser Valley's fitness, wellness, and endurance sports podcast
Re: Zwift & Cell Phones: Your recommendation [Hydrosloth] [ In reply to ]
Why can’t you just plug in your device?
https://www.strava.com/...tes/zachary_mckinney
I've used it a couple times with my S10e which seems to run smoothly.
However I also don't understand why you wouldn't use your "new" windows laptop??
I'm using an outdated Dell latitude (5years old, onboard graphics) which seems perfectly capable at medium resolution ... definitely a better experience than on my phone.
tbd I don't really notice the mediocre graphics after a while (esp. in races)
Why would your phone run zwift better than a pc? That seems quite curious
Strava
Re: Zwift & Cell Phones: Your recommendation [rsjrv99] [ In reply to ]
I switched from a Windows PC to old iPhone (6s). I was getting a lot of dropouts using ant and the Bluetooth works great. I use a “dongle” for power and monitor.
Re: Zwift & Cell Phones: Your recommendation [plant_based] [ In reply to ]
We've got a winner!!
Coaching: https://bybtricoaching.com/ - accepting athletes for 2023
Re: Zwift & Cell Phones: Your recommendation [natethomas] [ In reply to ]
Because that port is used to output to my big screen.
can you get a new phone with wireless charging? leave the phone on a wireless charging pad, which will free up the port for running to your display
the world's still turning? >>>>>>> the world's still turning
How about something like this:
"I'm thinking of a number between 1 and 10, and I don't know why!"
Re: Zwift & Cell Phones: Your recommendation [Warbird] [ In reply to ]
These both look like excellent suggestions. Thank-you v. much. Any specific phone recommendations?
I have ran zwift for a while now thru a google pixel 4, it works well.
I am an iOs guy but in general, make sure whatever android phone you go with meets the Zwift device spec:
https://support.zwift.com/...-run-zwift-H1Cj9QbeB
The big issue with a smart phone is screen size and BT drop-outs. now if you have a splitter and can output to a TV (or airplay, or whatever non iDevices call screen mirroring), and can use an Ant+ Dongle, then you're in business. I have only tried riding on Zwift once with my phone, but I've Zwift run through my phone numerous times (both at the gym, and at home, when my PC is too bloody slow to load, and I am just doing a quick run off the bike on the TM) and it's been decent, other than the small screen. I have a cable set-up in my paincave to charge my phone with, so I had no battery issues, and at the gym while running, the policy was max 60min on a piece of equipment, so I never tested the bounds on battery life...
Get an iPad. I use android and the iPad runs zwift much better than my phone even though the ipad is using a 4 generation old chip- A10.
Re: Zwift & Cell Phones: Your recommendation [kini62] [ In reply to ]
This. IPad 7th gen are pretty cheap. My Zwift runs amazing on one. I am an Android phone user.
Didn't some say here that an Apple TV box is the easiest and cheapest way to run Zwift?
Re: Zwift & Cell Phones: Your recommendation [NordicSkier] [ In reply to ]
Sounded like the OP was going to get a new phone regardless. If it were me, and the old phone ran Zwift with no issues, I'd probably get a usb/hdmi/power adapter and relegate that phone to permanent Zwift service on wifi, get the new phone and use that to run the companion app while Zwifting...
Only issue with the Apple TV is the 2 BT connection limit AFAIK. I just watch on my iPad.
Thank you.
Keep your Samsung S8 for zwift and delete all other apps. Buy an extension chord to keep plugged in while you ride. Or just get a tablet that can run it
I use that adapter on my iPhone 8S. Lightning/hdmi adapter. Although the lighting bolt displays that the phone is charging, the battery is still draining. I was at 85% on tonight’s Zwift ride, about 70 minutes the phone was down to about 40%
Re: Zwift & Cell Phones: Your recommendation [MKirk] [ In reply to ]
I use the Apple adapter with my iPad for Zwift. The first one I had did the same thing, battery level would drop during use. When I took it back, I was told it shouldn't be happening, and was given a new one. That one has worked perfectly for the last year, and will bring the charge up to 100% during a ride. I've seen several reviews that the Apple adapter can be hit or miss, like my experience, and that the knockoffs are usually worse.
I have a S10+ and a Roku or Chomecast on the TV, depending on which input my son left the TV I use either, but you can just use smartview and cast to the TV and then have the phone plugged in charging. Nice and clean setup, very little lag and the quality of video is just fine.
I use a similar adapter for Zwift (but with my Macbook) since Zwift consumes lots of battery power and my laptop isn't always charged. Works like a charm!
Re: Zwift & Cell Phones: Your recommendation [TJ56] [ In reply to ]
I found ANT to just inherently suck. Even the dongle on top of my trainer had dropouts. I switched to a Bluetooth receiver adapter that I connected to my pc and it works 100% now. Windows has native Bluetooth support and the Bluetooth dongle is exactly the same as the ant+, just a small usb bit
Strava
It would be really cool if I could reliably run Zwift from this laptop (HP Elite, I-7 proc, 12 G DDR). So that option of the Bluetooth dongle sounds like a neat option. How many $.
Less than $20 at any electronics store. I got mine for 15 at Best Buy. Fixed all my problems đź‘Ť
The laptop probably has Bluetooth already on it if it’s less than a few years old I’d think
Strava
