-W- wrote:
SummitAK wrote:
If you are riding from a PC you can delete or edit the knownequiment.xml file that stores previous connections. This fixed most of the same issues I was having. I recently started just editing the file for my Tacx and HRM, but Zwift will still sometimes try to connect to my wife’s trainer which is nearby. It may come down to signal strength so if using ANT+ get the stick as close to the trainer as you can. Not sure how to use these changes if running smartphone, tablet or Apple TV thru BTLE. knowndevices.xml on PC?
My ST email notifications stopped working a few months ago and I haven’t bothered to see about switching it back on.
Not sure what your question here is about?
PC is personal computer. I use Windows, but I suppose a Mac has similar file storage.
Knowndevices.xml is saved in your Zwift user directory in the main Zwift folder. Also stored there is Prefs.xml which can also be deleted to help “reset” Zwift. This is the file that Zwift hackers change to ride in different worlds.
I have not done this with iOS or Apple TV, but a quick search online shows this has been successful for iOS using added apps to get to the files. I also found info on how to modify Apple TV, but it wasn't clear if this results in some sort of device jailbreak.
I’ve seen the stryd behavior Ray mentioned above too. If it was a big issue for me it wouldn’t be hard to setup a scripted startup similar to the Zwiftprefs programs which swap out the knowndevices for the activity or equipment you’ll be using. Ie. ride vs. run.
