DarkSpeedWorks wrote:
anitan1 wrote:
Working on a Plan B... I'll update the thread as I know more.
Some good info to know. Is plan B to try instead to remove some material from the largest cog carrier of your cassette? Because that looks viable from a structural point of view, but, from my measurements, it also looks like the clearance between the protruding zipp hub aluminum spoke anchors (I have a zipp 182 hub) and the inner protruding parts of the largest cog carrier are going to be tight, maybe very tight. Have you measured that clearance? Anyway, if not, there is always a good 'plan C'
here.
Greg @ dsw
I've been trying to stay away from options that modify the cassette because I don't want to have to worry about this after I've done the mod (i.e. don't want to have to machine multiple cassettes in the future).
The question is: What is the main difference between the 11-speed freehub and the 10-speed freehub?? Is it just the length of the freehub and it's I.D.(i.e. axle diameter)? That's the rumor...One thing we do know is that the distance between the dropouts doesn't change.
So, current Plan B is to look at a hybrid of my old-style 10-speed wheel with a new 11-speed freehub and a new hybrid axle. The spoked wheel may have to be re-dished, because this option may shift the position of the rim slightly. However, I'm not even sure this is going to work because I'm not sure if the freehub will mate with the old wheels. But if the axle is the main difference, then designing and machining a new axle is totally in my wheelhouse. Also, not sure how the disc wheel would work with this, since re-dishing isn't an option. I'd love to know your thoughts on this.
