DarkSpeedWorks wrote:
anitan1 wrote:
Yep, I'll get more pics posted tonight or this weekend. What version of HUB do you have?
We have two. One is identical to yours, the other is an 07 or 08, and it is the one that I have more concern about. It looks like if you remove 1.7 to 1.8 mm of material the cassette might even rub on the hub body. Then, there is the ramped nature of the grooves, not sure how those could be milled out. See pic:
This one looks really tight, but I also see real estate beyond where the spline ends. So, we take the shoulder down all the way to the end of the spline and see how much material that would remove OR I'm left wondering if we could remove less than 1.8mm (say .9mm or .035") and essentially split the difference with the smallest cog. Thoughts?
I believe the groove between the shoulder face and the hub is inconsequential. Essentially it just serves to make a virtual corner between the surface of the spline and the shoulder, so that the largest cog will seat all the way against the face of the shoulder. Obviously, your other HUB, can easily be done. If you were to send me both hubs, I could take some measurements of the one pictured above and try to understand what the differences are.
