mknight84 wrote:
Does anyone have wiring routing pictures of di2 on a vuka stealth integrated bar? Thank you. Found a good deal on one and its making me pause on pulling the trigger on a alpha x.
We have a couple of these wired up with Di2 on our tri bikes. With a bit of patience you can almost completely hide all the wiring. Both of these builds use the EW-RS910 in the end of one aero extension. The extension shifter wires come out back of extension routed in small notch back on themselves and down the back of the extension riser where they can be taped or covered with heat shrink tubing. These then route to the cable/wire holes in the Kamm tail and inside the basebar. There is enough room to tie all the shifter extensions together using two JC-41 Junction B's and a short wire link or the 6-port Junction B from the SM-BTC1 internal battery external mount kit. The 6-port junction cylinder shape just fits through the round whole in the back of the basebar's stem.
I'll try linking a photo:
ETA: the photo link works but it won't show embedded here in the post:(
