In Reply To:
In Reply To:
I meant variations in Crr. Pretty sure Al has two entries for that tire. Though CdA varies too of course. ;-)
Drag data is at 30 mph (no, I'm not that fast over long distances - I race pursuit :-) )
Thanks Damon. I think there may be a danger in just giving a "total drag" number at just one speed. This is because the "drag" force related to Crr is constant (or nearly so) and the aero drag force varies with the square of the apparent wind speed. That means that a tire such as the Aero TT, even though it's great aerodynamically, may not perform as well at lower speeds due to the higher constant "offset" due to it's high Crr.
Here, I "reverse engineered" your tire data over a range of speeds from 1 to 35 mph and plotted the results. I was curious as to what the "crossover point" would be for the various tires where the better rolling resistance would win out over the better aerodynamics of the Aero TT tire.
As you can see, on this wheel, the both the Zipp dimpled 21C clincher and the Race X lite 21C actually have less total drag below 20-21 mph, while the 23C Race X Lite Pro is faster overall at speeds all the way up to 28 mph.
It's also interesting how the 23C RXL Pro is better than either of the two 21C tires listed all the way up to 35mph, even despite it's somewhat worse aerodynamics. That really says a lot about how valuable a low Crr tire can be.
NOW do you see why I was asking about having the wings put on a casing like the RXL Pro?? ;-)
I'm also thinking I may have to apply a bead of RTV to my VF Record front tire on my TT wheel....:-)[/reply]
hi tom,
what mass, rho and percentage of raw roller Crr did you use for the plot? Definitely the very best way to look at it for one's personal case!
