My advice I can think of (Granted, you are about 8mins faster up the Alpe than I am, so really it should be the other way around).
1. Try to average your 45min power. Which for all intensive purposes should only be 5-10w above your FTP. Hammer the last part past turn 1.
2. If there is any place to put a little surge in, it would be any time that your gradient is above 10%.
3. Just to be specific, the "Tarmac Pro" is the better climbing bike than the "Tarmac".
4. Treat this as a race. Try to do a mini taper, caffeine, make sure topped up on carbs, etc, etc.
5. I think the trainer difficulty is personal preference. I personally prefer to ride at 0%. I think riding at 100% just forces a rider to change cassettes. Technically speaking, if you were riding with a 34 little ring and a 11-42 cassette out back, you could probably ride 100% difficulty at 100rpm if you wanted to. 0% levels the playing field in my opinion. You still have to push watts in 0%, so I feel it's all the same.
6. If you are allowed to get a powerup, of course try to get a feather and use it on the steepest part of the climb.
I think that's all I can think of for right now.
EDIT: Ok last thing I thought of, is if you really want to maximize your "e-setup" you would use power pedal output as your power source for Zwift, and not the trainer's power source. This helps you "gain" all of the watts that are lost in the drivetrain of the bike. Could be 5 watts. Who knows.
- Jordan
My Strava
