cloy wrote:
I've been using an older Yakima hitch rack for a while now---two-timer---but ever since I installed it, the lack has leaned to the passenger side of my vehicle. It still carries my bikes, but it's been slightly irritating. Anyone have a fix? The hitch was installed level and it seems like the lean is coming from where the unit slides into the hitch mount or the piece that tilts the rack up and down.
Are you running just the normal cheapo thru-pin or do you have a nicer thread-in draw tight lock pin through the hitch mount point?
This makes a big difference in lean/sway in these kind of products. My Kuat came with both. On the way home the LBS had installed it with the cheapo thru-pin and it leaned/swayed badly. With the draw-tight lock pin it was awesome.
Some folks have used a cutup soda can to take up some slop in the fit between the hitch receiver and the bike rack. You don't need that though on the kind that draws the bike rack block tight into the hitch.
