TriTater wrote:
SRAM just unveiled a single chainring groupo for cyclocross, following on their successful MTB single-ring option. Interesting mention in this article that the triathlon market might be next: http://www.cyclingnews.com/...by-cyclo-cross-group I took a quick look at the gearing, and it looks like you could run a 46 tooth chainring and an 11-32 cassette, and you'd have a pretty good gear range for nearly all circumstances except downhill with a tailwind: about the equivalent of 34-24 for the low end and a 53-13 for the top. Maybe not big enough for the real hammers, but more than enough for us mere mortals.
So, what do folks think? Would you go with a single chainring setup like that, and shed all the extra weight and hassle of a front derailleur and double rings? Of course, your SRM's and Quarq's would have to go, too. I might do it.
N = 1, I wouldn't do it. Even living in the midwest, there are enough hilly rides and races that I do which require multiple chainrings. So far this year, I have done rides/races and used every bit of 53/38 and 11-28, and I'm doing a ride next weekend that will be best with 52/36 and 11-32. I don't want the huge gear jumps of an 11-36 or super-wide 10-42 (or whatever the new SRAM 1x11 MTB stuff is) for road. If I was a big CX racer, I would think about doing it, mostly because the overall speed range on a CX course tends to be much narrower than road riding, and FDs can get mucked up with mud. And it's one less cable to replace.
Clearly 1x systems will work for some folks in road applications (such as folks racing/training exclusively in Texas or Florida, and are on the fitter end of the spectrum), but I don't see it being an overall 'plus' for the lion's share of the market, given all of the considerations/factors involved. Even with two-chainring systems, a lot of people complain about missing a 16t cog (or whatever their cog of choice is) - taking away rings in favor of larger cassettes only makes the problem worse.
