In Reply To:
Quite a bit of data on rolling resistance is available. None supports this claim. Rolling resistance decreases with higher pressure, although this is a power function and the curve flattens out rapidly at higher pressure (that is, there is minimal gain in rolling resistance once a certain pressure is achieved in the tire).
Some of the worst technical misinformation comes from the bike industry. I can buy that cornering traction may be optimized at a certain pressure, but definitely not rolling resistance (and that includes rolling on rough pavements, in case someone wants to bring that one up).
Francois in Montreal
Uh...not quite true there, my friend. On a perfectly smooth surface, rolling resistance does generally go down with pressure going up. Real roads are nothing like that.
It's not the tire pressure
per se. It is shock absorption. That's why race cars have suspension. The smoother the track, the harder the suspensions settings. Rolling vehicles go faster when minimizing the transfer of road shock to the unsprung mass. Suspensions accomplish this. A suspension allows the "negative" force that a rough surface places on the wheel to be turned into heat, rather than transfered up to the body of the vehicle and turned into negative acceleration.
In the case of a bike, the tire is virtually the only suspension on the vehicle. It has to be calibrated to the surface to be ridden, and road courses are not like a velodrome or lab testing machine.
BTW -- the people at Michelin know a thing or two about this. They build Formula 1 and lots of other tires, after all. Their people have long advised road racers to ride at 120-140 and no higher.
