Tri-Banter wrote:
jakers wrote:
Also, when do you have better glide? With a full sleeve wetsuit? or in the pool with no wetsuit? Personally I feel a much greater glide while "my top arm is out of the water in its recovery phase" with a wetsuit on. Granted this will be helped by the thick panel down the front of the suit, but the 1-2mm thick sleeve will also help to keep you planed out during the "recovery phase".
So is the point moot? No. It is designed to be a performance enhancing feature on the wetsuit. Definitely separating a full sleeve and sleeveless.
Thanks for your response. I thought we were discussing a full suit versus a sleeveless suit. I am not questioning the buoyancy effect provided by any suit. I firmly accept, beyond any doubt, that swimming with a wetsuit is faster than without.
So, let's go through a thought experiment. We have 2 suits that are identical in all fashions (thickness, material, density, coating, etc). Wetsuit 1 has sleeves. Wetsuit 2 does not. In the argument pro-sleeves, people oft cite that the sleeves add more buoyancy versus a sleeveless. I doubt that the level of additional buoyancy created by one arm during the reach phase is significant compared with the overall effect created by the rest of the body (even at the banned 8mm thickness of the DeSoto Rover). When I recover, the arm is out of the water. When I reach, the arm is under the water by about 2-4 inches in a vertical plane. When I try to keep it on top, I catch a lot of air which is detrimental to the stroke. I just don't see how the added buoyancy of the sleeve helps me here. Just curious is all.
As I just learned from other posters, and accept, it may not be the buoyancy in the sleeves but the additional surface area. Also, many sleeves have a drag feature on the forearm to increase catch resistance, so that counts too.
FWIW, I have both sleeves and sleeveless. My fastest IM swim was in a sleeveless wetsuit. But, I am crediting better training for that success and not the lack of neoprene in the arms.
I accept too that the full sleeve wetsuit has more buoyancy during the reach phase and should be faster. Aside from a few Ironmans in the mid 90's which were all done before I busted my shoulder (now have reduced shoulder mobility), all of my fastest half and full Ironman swims have come with
no sleeves. Perhaps for me, the full sleeve also hurts some of my "already reduced" mobility. Generally though, I keep using the full sleeve suits, because it is too cold around here for all but 1 month to use anything else, and I like to believe that guys like Desertdude who have done fairly controlled tests, have the data to back things up....perhaps my fastest times have come in sleeveless suits, because those races were later in the year, and I'm just in better swim shape, given that I stop swimming every winter...in a good year I start up swimming in March, in a bad year, I start up in mid April...so that might be the biggest culprit. I'm just pointing out that there are many factors at play that we probably should not overlook when making statements that we are faster in no sleeves. As you can see in my case, there are a ton of variables at play. Perhaps I need to go swim on a marked course that is 400m in length with no current, and alternate between suits, and wear a heart rate monitor (yikes....is taht even approved on ST?) to keep the effort the same!
