Etip wrote:
Recently picked up some P1s. I think I can an use my 920xt to view power, but it's a small cluttered screen.
Would like to leave on the bike.
What do folks use?
Thanks
Don't let me talk you out of a dedicated cycling computer if that's what you really want. But a 920xt with a quick-release would make a perfectly fine bike computer for most functions other than navigation.
I have a 310XT that I use on the bike to record and display power. With the QR kit, it mounts right up to a Garmin 1/4 turn mount.* I would recommend setting up multiple display "pages" with 3 data fields (one big on top, two small on bottom.) On every screen, I would suggest the top (big) data field be 3- or 10- second power. Use the lower data fields on the other screens to put other info in you'd like to see (for example, average power, distance, elapsed time, HR zone, etc). Then set the watch to auto-scroll through the pages. As the screens scroll, your current power is always the most prominent # on top. The other data essentially scrolls across the bottom. There are 3 speeds of scroll. I think I use medium, can't remember. It will cycle through the 4 pages I use every few seconds.
*FYI, the ears on the 1/4 turn "stud" of the QR kits are oriented 90 degrees from those on a Garmin Edge. Had to be this way to allow the charger to attach to a 310XT. I think the kept it on the 920XT to keep the band base narrower. Some Garmin-style mounts allow you to rotate the base to accommodate this difference, but some don't. Just be sure the mount you buy does have the flexibility.
