Bdaghisallo wrote:
jazzymusicman wrote:
i run two Vornado 733's. it's glorious the amount of air they move
https://www.amazon.com/gp/product/B000MI3HJQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B001DNGSCM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
These Lasko fans are better. I have the Vornado you referenced, and the Vornado 293 referenced earlier, and this Lasko outperforms them both. Two of these Lasko fans pointed at you and you will be set.
This Lasko fan seem like the wrong solution to me, especially if he has to locate it close to himself.
You want a large airflow over a large area at moderate speed for the best cooling and comfort. Axial fans are not good for developing high pressure, but you don't need or want high pressure in this case and an axial fan will do fine. I don't see any advantage in a centrifugal unit like that Lasko fan. Given the much smaller outlet compared wuth a large axial fan, either the air velocity is far higher or the total airflow is very low. I expect it's the former. Surely you'd be better off with a basic axial fan?
It might be a perfectly good fan, but it's the wrong tool for the job, IMO.
