I've seen the claim floating around slowtwitch that run pods are more accurate than GPS for measuring distance/pace while running. There is also this link which seems to show that run pods are more accurate.
I thought about a home project to make a run pod using an IMU, but when I started to investigate methods, I couldn't find much claiming that they are better than GPS. This paper seemed to be a good survey in different techniques and only 1 of the 4 methods was comparable to GPS. The pods seem to work by having a calibration phase where you run a known distance. Then they can count the strides and calculate your distance/stride, which can then be used to get your total distance and speed for future runs. The issue is that people don't have the same stride distance over varying speeds. Which means the pod is only good for the speed you calibrated at.
So I'm curious how do these run pods actually calculate your distance and pace?
