knighty76 wrote:
I assume Friel doesn't advocate for adding this TSS number to your other TSS numbers? For example, your cycling TSS?
Because that would seem kind of nuts to me. Different energy systems. I'm not even totally sure about adding together your bike and run TSS, in terms of how meaningful it is. I think it was Dr Coggan himself who advised against combining TSS and rTSS into a single metric. Isn't it common practice to plot CTL, ATL and TSB separately for the different disciplines?
What do you want to do with the "weights" TSS number, out of interest?
Cheers, Rich.
I think TSS is relevant to an extent. Its all about your bodies resources. When you lift weight you are causing trauma to your body and it then need to go repair it to recover and get stronger. That effort will take away from the recovery of your aerobic training. I am curious myself how much it translates.
I was a bodybuilder prior to tri and slowly have spent less and less time in the gym. Last year I was able to train pretty consistently up to 25hr/week while only doing moderate strength work 2-3hrs/week without getting overtrained. This year with no races I have been determined to try and crack the 1000lb club (Between squat/DL/Bench) and I am lifting pretty hard 4-5hrs/week. If I go above 16hr/week right now, I start to show signs of overtraining.
Its possible there are other factors and presently trying to figure them out because I am not a fan of trading 9hrs of tri training for 2hrs of strength work so hoping to find another kink in my plan but could just be the lifting.
