SPM/Running cadence at a given speed/RPE/whatever?
Re: We all know that 90RPM is rubbish, but what about... [lemos]
Oh for frucks sake, why does this shit keep coming up.
Just run, your body will find it's own natural cadence.
it's bs too, otherwise taller people will always be faster
sorry, what I meant was. What if we try to dial in the cycling cadence by using our running cadence as reference?
lemos wrote:
sorry, what I meant was. What if we try to dial in the cycling cadence by using our running cadence as reference?If you do not already have a solid reason to believe there is a relationship between the two, don't try and invent one.
Since you did not provide a reason, I don't believe you have one.
I don't think there is one.
Incidentally:
My typical cadence ranges are Run: 182-188spm. Cycling: 75-90rpm
My training buddy's ranges are Run: 158-165spm. Cycling: 85-95rpm
How is that useful?
Can you see any reason to think one of us is doing something wrong by comparing the two disciplines?
Re: We all know that 90RPM is rubbish, but what about... [Ai_1]
Ai_1 wrote:
lemos wrote:
sorry, what I meant was. What if we try to dial in the cycling cadence by using our running cadence as reference?Why?
Incidentally:
How is that useful?
it's just food for thought. Chill man!
Just in talks with some friends there is an idea that if you have a similar cadence going from the bike into the run, it will be more beneficial, as you won't have to change the speed at which your legs turn.
For instance, a 90RPM cadence, would benefit a 180spm run, 80RPM cadence a 160spm run, etc. So, although we naturally select, one could argue that there could be a benefit trying to match the two together. rpm*2 = spm.
Incidentally:
How is that useful?
Actually it could be useful.
You are both doing the inverse between disciplines.
So either high run, low bike, or high bike, low run.
Which suggests that it may be optimal not to do 'high/high' or 'low/low'.
Just a thought ;-)
Incidentally:
How is that useful?
I actually thought about this myself a few years ago at a time when my own typical cadence was extremely similar for both disciplines. I didn't see any specific reason why they should be similar. They just were. Since then my typical cadences have diverged. My run cadence has increased very slightly and my cycling cadence has reduced while at the sme time I've become faster at both. So I'm not reading anything into it.
If you've got an argument, I'd love to hear it.
Sincerely. But I don't see an obvious link or hear an argument.
My run cadence is 185-200 & bike cadence is around 84.
Not sure how those correlate, but my HR at 185spm is equal to my HR at a 84rpm cadence - @ 1.1/w to kg.
HR at 200 spm is equal to 93rpm at 2.0/w to kg
Re: We all know that 90RPM is rubbish, but what about... [lyrrad]
This discussion needs more Velotron.
Re: We all know that 90RPM is rubbish, but what about... [tuckandgo]
Incidentally:
How is that useful?
Just a thought ;-)
That's an awfully small sample size to "suggest" anything.
Re: We all know that 90RPM is rubbish, but what about... [mickison]
Yes, this needs more velotron.
Also, I can tell a lot of the tri folks in here have never bike raced. There's a really really big reason those guys hold 90rpm and 100rpm when they do. If it's lost on you why they do that, then you don't need to worry about it.
Incidentally:
How is that useful?
Just a thought ;-)
Yup, that's the 'fun' thing about the internet, you can talk shit as if it has validity (or at least a lot of people do)
Re: We all know that 90RPM is rubbish, but what about... [MattyK]
MattyK wrote:
This discussion needs more Velotron.And 200mm cranks :)
I have noticed a correlation in sprint races. A high bike cadence leads to a higher run cadence and faster run. In fact...I just did a 30 min warm up on the bike trainer at an average cadence of 106 and then raced...and won...a 5k. Set a PR as well. Average cadence on that run was 182 with a max cadence of 210.
Over the longer haul I could see a high/low or low/high combo worker as you are doing aerobic/anaerobic balance.
Physiologists know that muscle efficiency all comes down to the speed at which your muscles can contract. If you choose a gear and cadence that allows your muscles to contract at one third of their maximum velocity, you’ll maximise your power output.
Read more at http://www.cyclingweekly.com/...#e1XUEs6OWb1zS0O2.99
lyrrad wrote:
Oh for frucks sake, why does this shit keep coming up. Just run, your body will find it's own natural cadence.
This is what happens when engineers dominate a sport.
Long Chile was a silly place.
Re: We all know that 90RPM is rubbish, but what about... [burnthesheep]
burnthesheep wrote:
Yes, this needs more velotron. Also, I can tell a lot of the tri folks in here have never bike raced. There's a really really big reason those guys hold 90rpm and 100rpm when they do. If it's lost on you why they do that, then you don't need to worry about it.
https://fitrecovery.wordpress.com/2014/09/19/cycling-speed-and-cadence-why-the-90-rpm-cadence-is-so-important-to-cycling-fast/
Because not worrying about it isn't for everyone.
MattyK wrote:
This discussion needs more Velotron.I got a fever. And the only prescription. Is more Velotron
Re: We all know that 90RPM is rubbish, but what about... [LifeTri]
LifeTri wrote:
Physiologists know that muscle efficiency all comes down to the speed at which your muscles can contract. If you choose a gear and cadence that allows your muscles to contract at one third of their maximum velocity, you’ll maximise your power output. Read more at http://www.cyclingweekly.com/...#e1XUEs6OWb1zS0O2.99
Re: We all know that 90RPM is rubbish, but what about... [JoeO]
JoeO wrote:
Swimming Workout of the Day:
Favourite Swim Sets:
MattyK wrote:
This discussion needs more Velotron.Clearly we must run at our natural cadence since we're unencumbered by mechanical confusion.
So of course we should ride with that same cadence.
If you run at 180spm, you should ride at 90rpm (i.e. 180 power strokes/min at the cranks, we'll call these "powercranks" for short).
So we know the correct cadence. Now we just need to identify the most efficient crank length for achieving that cadence at the desired power. We can use a velotron to ensure repeatable testing. Lets start gathering some data! We all like data right? We'll figure out what to do with it later.
Of course I already know what we're going to discover.....
I'm 1780mm tall. It's another 20mm from the sole of my foot to the pedal spindle. So 1800mm or 180cm.
I think it's safe to assume the ideal setup is as follows:
- Rider height to pedal spindle = 180cm
- Optimum run cadence = 180spm
- Optimum bike cadence = 180pc
- Crank length = 180mm
- Optimum efficiency power = 180W
- HIM bike time = 180min
- My IQ = 180
Yep, it all seems to work!
All you guys not using a velotron are sheep. Be unique just like me. We are all individuals! ;)
No, but there has to be a SYSTEM, and charts, graphs, details, numbers, metrics . . and somewhere in all of that lurks the SECRET workouts that are REALLY going to make the difference!
Good grief - just run. Run easy. Run hard. Run fast. Run slow. LOVE running.
Steve Fleck @stevefleck | Blog
Re: We all know that 90RPM is rubbish, but what about... [BCtriguy1]
No, it's what happens when people think that changing a crank length makes them run faster. They have to get to Kona at all costs so why not spend more money because it makes them "faster"?
lemos wrote:
sorry, what I meant was. What if we try to dial in the cycling cadence by using our running cadence as reference?My running cadence is dependent on my speed. Jogging is 180ish and 5k race pace is 200ish. My bike cadence is independent of power 80-90 depending on terain. I see zero correlation between the two, interesting thought though.
I actually think cadence IS important.
The worst runners I see ALWAYS have a ridiculously slow turnover.
Maybe it is age.
Maybe they think their turnover is fast.
But they look like they are stuck in slow-mo.
Maybe it is age.
Velocibuddha: May 9, 18 12:35
