JDinMA wrote:
This measurement site is at the 'crib' which is a water intake structure a few miles offshore of the beach where the swim will take place. I would expect the water at Edgewater beach to be warmer. I've spent a lot of time sailing/coaching there. https://www.ndbc.noaa.gov/station_page.php?station=45176 eta:
There is also this map:
https://ny.water.usgs.gov/maps/nowcast/ Not sure where they are taking the measurement.
The map shows the temp at Edgewater Park at 72.3 which lines up with the 72 degrees that was posted to the event FB page. Reportedly taken using USAT protocols.
Not sure why the temp at the crib would be almost 5 degrees higher, like you I would expect the opposite. If you look at the data for the crib it did go up 2 degrees from the morning likely due to the sunlight at the 1m depth.
I did a lot of sailing there too, back in the 80s!
