My legs sink also. If I swam only a 3:00/100 (half my regular speed) my legs would be nowhere near the surface. With a combination of a strong core, a an adequate kick and relative speed I can keep my legs near the surface. Like another poster said, swim some faster 25's. With a light kick you should be able to keep your legs up. Then progress from there.
quote bretzky]
Keeping the legs up in the water is NOT about speed. Yes, it's true that the faster you go, the easier it gets, but I can definitely swim a 3:00/100yd while totally banded at the ankles (intentionally going that slow) and keep my legs up with zero kick. There's a youtube video of a swim instructor going from vertical to horizontal with zero kicking just with small changes in body positioning. That's what you're striving for. It does NOT take a lot of energy to stay flat in the water if you are doing it right.
I disagree with all the folks recommending you work on your kick. The kick should NOT be used for leg buoyancy - that's a horrendous waste of energy and a lot of AGers fall victim to this. You should learn to be flat in the water without your kick, and only THEN start putting your kick back in as a source of propulsion.
I'm not a swim coach nor am I a FOP swimmer, but I've had my share of struggles, and I suspect you'd hugely benefit from spending a few weeks doing nothing but working on swimming with an ankle band (with progression, not just completely failing at it repeatedly). It's a self-correcting aid - if you can swim 50yds with it, you at the minimum are keeping pretty good body position, eliminating fishtailing, and have a fairly balanced pull. Again, swimming flat should NOT require a lot of effort, in fact it should require very low/minimal effort.
Any tips how to achieve this? Or just work on engaging the core, glutes etc to become comfortable being flat in the water. If I put a band on my legs sink to the bottom.[/quote]
quote bretzky]
lightheir wrote:
Just to chime in - Keeping the legs up in the water is NOT about speed. Yes, it's true that the faster you go, the easier it gets, but I can definitely swim a 3:00/100yd while totally banded at the ankles (intentionally going that slow) and keep my legs up with zero kick. There's a youtube video of a swim instructor going from vertical to horizontal with zero kicking just with small changes in body positioning. That's what you're striving for. It does NOT take a lot of energy to stay flat in the water if you are doing it right.
