So I am clearly WAY late to the party here!!
So sad to me to see how little credit Zipp got for any of this... when we launched Firecrest in 2010, we did with its some amazing supporting data including 3 prior years of AIAA papers developed with Matt Godo... we were the first to talk about transient behavior, and then developed the models for handling stability..the first to extensively use the Aerostick to test and later validate handling improvements...etc, all of the other stuff mentioned here from every other single company has benefited from the work done to develop Firecrest (especially the work of Matt Godo.. we even became the first non-military winner of an Innovation Excellence Award at SuperComputing 2012), which makes me super proud, so hard to see it forgotten so quickly. Rant over.
I really like the way the Hambini crew have tried to put numerous variables into one single test.. it's an interesting attempt to blend real world data into something new and better. One of our secrets at Zipp was that our tunnel protocol went 0-30 and then built the curve stepping back to zero.. so it started with detached flow and measured when it all came back together rather than the other way around which led to shapes that seemed to be more forgiving of transients. Many wheels (and bikes) have large hysteresis when comparing 0-30 to 30-0
Past all of that, I have no horse in this race so my questions are all based on logistics:
1. What tunnel was this done in and who/how was it paid for? I see the it says weekend project for engineers, but with a 1600 second (26+ minute) protocol run time per velocity regime, you are looking at ~1hour per run time per setup assuming spin-up/spin-down time turn on of data acquisition, etc..then assuming a minimum ~30 minute de-fixture/change wheels/re-fixture, re-zero, and water the rider time this makes for 1:30 absolute minimum time required per wheel model if you're running it like an F1 pit crew.. I count ~30 fan-on hours here plus probably 50% more in fan-off time plus 2x that amount in post processing.. and that's assuming everything is perfect all the time. So that's a long way of asking if you are trying to monetize this in some way or if it was covered by other means?
2. Is the tunnel used for other things?
3. Did you have to tear it down and set it up each weekend or whatever to do this over a few months?
4. Was the same rider used for every test and if so, how did you find somebody who could/would ride a 26 minute tunnel protocol back to back at the required level of physiological stability required to net a +/-2.5% max error?
5. Is the tunnel temperature and pressure stable or is this accounted for in post processing? I'm assuming this took a few months to complete so ambient had to vary quite a bit?
If nothing else, I love seeing the discussion on these topics as we try to move the state of the art to the next level.
Josh
http://www.SILCA.cc Check out my podcast, inside stories from more than 20 years of product and tech innovation from inside the Pro Peloton and Pro Triathlon worlds!
