kileyay wrote:
There are still the variables that nobody will agree on. You have chosen to test wheel only, and apparently wheel only closely aligns with wheel in the bike, per Tom A. Maybe on the Dimond Superfork, but on the 3T Strada I find it impossible to believe that my ultra wide Enve 4.5 ARs together with respective tires and pressures tests much differently as a system in that fork, with its couple mm worth of clearance to the fork, than those wheels would in, say, the new Ceepo, among others.
I agree with you on this point. With wide forks, perhaps wheel only testing is sufficient. With narrow clearances I can't imagine that doesn't change and there's been some wind tunnel tests out there that show as much. I *believe* Grill did some testing with a P5 and an 808 front which showed the whole system was surprisingly picky with regards to tire selection... more so than wheel only testing would suggest.
kileyay wrote:
Canadian wrote:
Take the following as an example. There have been several crowd-sourced studies on this forum. One, in particular, added hundreds of grams of drag worth of error to their results in how they set up their tires. Yes, hundreds of grams in just the tires. Conclusion, the results are useless. Separately, I do think it's basically chicken shit that you haven't tested your wheels against two of the industry leaders, say Enve and Zipp of equivalent depth, while soliciting the information from those companies for optimal configuration. For all the time and money you have spent in and on aero testing, I don't understand why you couldn't spare an hour to do very basic competitive testing in line with the instruction of your competition.
I'm in agreement with you on this as well. Considering all of the testing Flo has done, it would have been rather trivial to compare their wheels to a 303/404/808 or Enve's equivalents. Just send them an email and ask them what tire they recommend.
Disc brakes may die but I'm going to hold on to my rim brake wheels for quite a while. Hearing the rotor go "ting, ting, ting..." while riding to the pool isn't the end of the world but it would drive me absolutely nuts on my TT bike. Given how baggage handlers treat bike cases, it seems like a guaranty that you'd have to true your rotors if you flew to a race.
