Either I'm doing something wrong or tubulars are just vulnerable to this problem. In the past it never happened. During those halcyon days, rims were shallow and no one was using extenders. I recall most of my tires had threaded valve stems...could be the indirect causative factor with modern deep section rims through the inability to 'lock' the valve stem in place during inflation. There's a lot of movement both vertically and laterally when inserting/removing a floor pump head, inducing wear and tear after many inflations. It's unavoidable.
This is an issue that NEEDS to be addressed by manufacturers. Either they should provide reinforcement to susceptible areas of their tubulars or the aftermarket should start producing threaded extenders. Myself and those people who posted here cannot be the only people who have fallen victim to this kind of failure. I'm not being hyperbolic. Most of these ruptures resulted in
sudden loss of pressure; it could lead to a serious situation at speed. Fortunately, I wasn't riding very fast in any of these incidents.
ericMPro wrote:
the answer is switching to clinchers (or a tubular) with a threaded valve latex tube, so that you can seat the nut against the rim and prevent any valve leakage or seam or pressing to inflate issues, which is their only drawback IMO.
I use valve extenders. If you know of any with threads on them I would love to get some.
SharkFM wrote:
Had the same issue with the Vittorias, probably went through about 4 tires. Took one apart - quality constructed and robust design at the valve base. There was just a hole tear that opened up the latex tube. Very strange.
It's not only Vittoria. Not sure, but I believe I've lost more tires from Continental to this problem. In truth no manufacturer is immune. It's the nature of the beast with modern deep aero rims, I'm sure of it.
Quote:
Have had good luck with the Tufo, just bought a couple of sets of the high carbon tires (25mm) from Wiggle $50 each. Also got a set of 28mm from Ebay. Nice tires.Good to know, might check them out. Maybe they are more resilient in that area of the tube. Wish I had a list of tubulars with that kind of specifically designed construction. At wit's end...
