Tririg Omega X and Shiv Tri
I have the original Omega brakes on my Shiv Tri and the wife now wants the updated version on hers.
I am led to believe that the TRP posts have to be removed to allow the attachment of the new adapter.
So my question is - has anyone had any problems removing the posts, are there any tips or tricks.
I am assuming that once I get started I cannot stop or change my mind and, as it’s an S-Works XS frame it could be an expensive and difficult to replace mistake.
Also has anyone installed an Alpha One on a Shiv. I want to put one on wife’s bike at the same time but she is not sure about how it looks!
If so, could they post a picture
Thanks
Coxy
Re: Tririg Omega X and Shiv Tri [coxy_in_nz] [ In reply to ]
Ya, removing those posts are a total PIA. I used a generous amount of PB blaster, a pair of locking pliers, and some elbow grease. Got those fu$#ers off though!
Re: Tririg Omega X and Shiv Tri [treyedr] [ In reply to ]
Space Shuttle landing type of operation then - you only get one chance.
Was there any point you thought you weren’t going to succeed?
Coxy
Yea they’re terrible to get off but the Omega X brakes are totally worth it. I was afraid I was gonna mess my frame up so I took it to the LBS and using a vice they had them off in literally 30 seconds.
Re: Tririg Omega X and Shiv Tri [triguy86] [ In reply to ]
Understood.
Although it looks like I’m a Kiwi, I’m actually Australian.
Brute force and ignorance are our speciality!
Thanks
Coxy
Na....just lube it up really good, then bang away.
Really nothing to be afraid of. There is some loctite on the threads, but it's not that difficult to remove them.
The Alpha X looks great on a Shiv. It's relatively easy to modify the original top cap to make it fill the gap behind the stem and fit the stem itself.
Re: Tririg Omega X and Shiv Tri [chicanery] [ In reply to ]
Just a followup to my original post.
Had the opportunity to have a good look at the brake mounting posts and can report that the base of the post incorporates two flat sections that allows the use of a spanner (wrench). Was able to loosen post with no difficulty. For some reason, i thought they were circular for their entire length and would be difficult to remove - they not.
Coxy
