Currently I am using Compressport TR3 Aero Trisuit
I am happy with that and like compression effect on upper legs in those shorts, but I think I could save more watts by using some short sleeved triathlon suit. I also compete in local TTs, do not want to invest in dedicated TT cycling suit so I could use that short sleeved triathlon suit for these also.
Where I live I do not have shops to try and buy so only option is UK or DE online shopping
Currently I am looking on Orca RS1 dream kona or Castelli all out speed tri suit
Anyone has an experience in full IM racing in these?
And also can anyone comment on fit? I am 173cm tall and 68kg that is 150lbs and 68inch. In suits measurements specs I am right between S and M size, but lower body is more like M (I can never wear S shorts because they are uncomfortably tight). Compressport I am also wearing M, but upper of that suit is a bit (but really only a bit) loose, but lower is just right (tight but not too much).
Also can anyone compare padding of the Orca and Castelli tri suits? I really like the minimalist style of Compressport, to be able to run very comfortably. And also what about outside of the padding? (compressport has little rubber bubbles so I do not slide of seat wile riding).
