On the bike: Athlete A is overtaken by athlete B. Athlete B's lateral draft zone is wide of A, but A does not drop back. Is that drafting?
Re: Triathlon drafting question [squid]
Depends what race, sanctioning body, and rules that were in place.
For IM, Athlete A has ~25secs (I believe that's the time limit) to drop back. Athlete B has to move over to the right once passing, otherwise they can be given a "blocking" penalty. So, technically both athletes could be committing rule infractions and receive penalties.
Is there a draft in that position, depends where the wind is coming from?
-Brad Williams
Website | Twitter: @BW_Tri |Instagram: @BW_Tri | Strava | Co-Founder & Coach at: KIS Coaching
Partnered with: Zoot Sports | Precision Fuel &Hydration | ISM
-Brad Williams
Lateral position isn't part of the equation. A is drafting if he doesn't drop back and B is blocking if he doesn't move to the right after passing.
Athlete A is overtaken by athlete B. Athlete B's lateral draft zone is wide of A, but A does not drop back. Is that drafting? //
Yes, that is drafting once you have used up the allotted time you are allowed to drop back..
