Tri Rig brake
Anyone know the screw size for the Tri rig brake cover. I have one bolt that is stripped and need to replace it
Re: Tri Rig brake [dl1340] [ In reply to ]
It is a popular brake here so I'm sure someone can help you.
What I do when I can't find a bike bolt size in a spec, is start with a bike bottle cage bolt. You know that is an M5 and then go bigger or smaller from there. So the bolt I needed for a Sram shifter was bigger. Tried the next bigger one I had, it was the perfect width. Measured it to confirm it was an M6 (google the specs). That bolt was way too long so then you put a nut on it and spin it down to the length you need and measure that. Then just work out what head is on it (google 'bolt head types'), it was counter sunk. So the one I needed was an M6 14mm counter sunk, worked a treat.
Going from the Omega X parts list I would guess it is a M4 bolt.
I'd replace every bolt I could on those brakes. TriRig bolts strip very easily.
Powered by All Out MultiSport - http://www.aomultisport.com/
Re: Tri Rig brake [SummitAK] [ In reply to ]
Yes, and here is the same parts chart for the original Omega. It is a 12mm M4.
