Just curious to see how many have this setup on their bike. I've got the bars , brakes. Looking for someone who experience running this setup. How does work? Love to see some pics if anyone has them!
Re: TriRig, Alpha +Onega × Delta cover? [crujones#33]
Of course you can see how it looks on Omni, those are all the same components - http://www.TriRig.com/Omni
Or you can see a bunch of other customer rigs we have featured here: https://www.tririg.com/...New_Age_Grouper_Rigs
Or a very nice P-Series Disc with Alpha One and Delta, here: https://www.tririg.com/...tom_Cervelo_P_Series
Or check out the photo roll on our Facebook page at http://www.Facebook.com/TriRig
Hope that helps!
TriRig.com
Hope that helps!
TriRig.com
Re: TriRig, Alpha +Onega × Delta cover? [TriRig]
What rear bottle holder is shown in the pic of you (?) on the Omni on this website page??
I'm running that. Will send pictures in a day or two...bike is in some pieces undergoing an overhaul.
It's mostly OK. I've had am issue with the Delta cover slipping down, for example on really hard bumps. This is bad because the front tire catches the Delta, and flings it off. Fortunately the two times it happened, nothing was damaged (and it wasn't in races). I'm considering using nuts on the set screws used for retention to avoid that. Or some other method. There's a very real chance this is all some sort of installation bungle on my end, but it *looks* OK when installed, to me.
Re: TriRig, Alpha +Onega × Delta cover? [trail]
Did you use the L-shaped tape on the fork legs?
Also if your bars are slammed right above the Delta, you can swap the set screws for button head screws and that makes it VERY secure.
TriRig.com
TriRig.com
Re: TriRig, Alpha +Onega × Delta cover? [DFW_Tri]
TriRig wrote:
Did you use the L-shaped tape on the fork legs?Ah, forgot about that critical point. I did originally, but it got bungled up after taking the Delta off a few times for brake adjustments, etc. And haven't found a nice tape to replace it with yet. Which is certainly another option.
Using head screws is great. Super secure and then you don't have to bother with taping and removing tape everytime it comes off. I have some L shaped tape around and I honestly had no idea what it was for until now haha
Benjamin Deal - Professional - Instagram - TriRig - Lodi Cyclery
Deals on Wheels - Results, schedule, videos, sponsors
Re: TriRig, Alpha +Onega × Delta cover? [realbdeal]
I also put screws into mine. Rock solid and doesn’t move. Without them the cover would rub my tire.
Favorite Gear: Dimond | Cadex | Desoto Sport | Hoka One One
Re: TriRig, Alpha +Onega × Delta cover? [The GMAN]
Where are you installing screws to hold the Delta in place? I'm not a huge fan of the tape method.
yes would love to see some pictures of that... thank you all
Tridad
Tridad
