Trainerroad training plan to Trainingpeaks
Has anyone tried this? I tried but not that familier on how to work in javascript. I'm stuck at seeing the output after pasting in the code from the link.
https://github.com/pchalacis/trainerroad-to-trainingpeaks
Or is there another way to import a TR training plan to TP?
Copied from the link above:
  1. login to your Trainer Road account, and open the plan. (Go to training plans, select phase and plan...).
  2. If you're viewing triathlon plan, you have to open weekly tips for every week (just click on week tips for each week).
  3. Open https://raw.githubusercontent.com/...mised/trainerroad.js file and copy it's content.
  4. On your Trainer Road window, open javascript console (for eaxample, for Chrome view -> developer -> javascript console).
  5. In the console, paste content of the file from step 3.
  6. In the output you'll get a blob of text. Select and copy it.
  7. Login to your Training Peaks account
  8. Open javascript console and paste what you copied in step 6.
  9. Open https://raw.githubusercontent.com/...sed/trainingpeaks.js file and copy it's content.
  10. Paste it to the Training Peaks window console.
  11. You will be asked for the date when you want to start the plan
  12. Enter the date, hit ok, wait 10 or 20 seconds and then refresh the page. all workouts should be there.
Re: Trainerroad training plan to Trainingpeaks [s.gentz] [ In reply to ]
I have used it. If you follow the instructions precisely it works exacly as advertised. Very useful. It does not transfer over the workout structure, so if you were planning on using the TP app on your Garmin or importing to Zwift you are SOL, but for planning by TSS it's perfect.
Re: Trainerroad training plan to Trainingpeaks [MattRudd] [ In reply to ]
Where is the output? When I paste in the link then hit enter it does nothing. I’m not really familiar with how JavaScript works.
You will need to run the code block in your browser console.
Any chance you have the time to step by step it like I am 8?
It says to open TR and open javascrript so I open to my TR calandar that has my plan loaded. Hir shift,ctrl,J to open Javascript console. When I do I paste in the code from the link. I either get a "failed to loas workout" timed out error or
"there page you're at has no workouts"
Understand if you don't want to bother. Thanks for your initial response and followup.
I can up to a point, I'm just away from my computer. I'll do it up to loading into TP as I don't want to have six weeks of duplicate workouts. I'll try to get it up by this evening.
Thanks. Much appreciated.
Worked for me. I would guess that you are looking at the calendar instead of the training plan for step 1.
So, for sweet spot base low volume II, make sure this is the page you are on for step 1:
https://www.trainerroad.com/...t-base-low-volume-ii
That's awesome, I've been doing this manually for years!!! Thanks for posting! Worked perfectly for me. Who posted the original? I'd like to say thanks!
Re: Trainerroad training plan to Trainingpeaks [Spartan_Pat] [ In reply to ]
Got it. I was trying to use the console on the training plan I applied to my TR calendar.
Thanks for the help.
Got it sorted. Thanks for your help.
Frustratingly I have got this to work before but now I'm getting an error. After following the steps (pretty sure all!), the Google Chrome DevTools window for TrainingPeaks gives the following error message:
VM402:1 Uncaught TypeError: $.get is not a function
at importer (<anonymous>:1:114)
at <anonymous>:1:1386
I'm a bit baffled - if anyone has a clue then please let me know. Thanks
Re: Trainerroad training plan to Trainingpeaks [rcsa] [ In reply to ]
Looks like jquery is not loaded. Can u show the code blok?
Did you ever get this sorted? I'm getting this error now. Not sure what to do.
VM115:1 Uncaught TypeError: $.get is not a function
I am getting the same error as below.
VM195:1 Uncaught TypeError: {(intermediate value)(intermediate value)(intermediate value)(intermediate value)(intermediate value)(intermediate value)(intermediate value)(intermediate value)} is not a function
at <anonymous>:1:23368
Any ideas? Exporter the data fine. Pasted into console, then pasted the code from the github import after.
I just did some googling and read that the API is broken on the TrainingPeaks side to do this and it no longer works.
Re: Trainerroad training plan to Trainingpeaks [Rossguy] [ In reply to ]
I had issues the most recent time I tried to accomplish this - that would explain it.
VM205:1 Uncaught TypeError: $.get is not a function
importer @ VM205:1
(anonymous) @ VM205:1
Has anybody found a turn around?
