burnthesheep wrote:
MattRBrewer wrote:
There's a local sprint distance around that I'm looking to compete in for the first time that may or may not commence, but entertain the idea that it does:
The bike route passes over train tracks that historically cause an incredible high rate of flats, yet the organizers haven't made an attempt to avoid this.
Is it common for tracks to cause flats easily or does it sound like it just may be this particular crossing?
Is there a certain way you're supposed to ride over tracks (bunny hopping, slow, fast, at an angle)?
Lastly, should I just dismount and avoid altogether?
Your wheels need to be as perpendicular as possible to them to avoid sliding in the gap and crashing, first. Next, lots of people run their tires at the wrong psi. Low or high. Too low and they're probably pinch flatting.
Myself? I don't bunny hop but just preload and unload my weight a bit going over them. If it's a series of lots of tracks, just stand up and act like your legs are shock absorbers like mountain bike riders do.
Great advice above and last sentence above is spot on. Even if everything is perfect, any time the bike is crossing an edge (tracks, driveway entrance, etc.) at a minimum you should unweight the bike. At a minimum, I recommend every rider should be able to clear a prone water bottle by bunny hopping, ever if slow lifting front tire and then rear. Clipped in makes it crazy easy. At speed, takes a little more practice and confidence but is has saved me from crashes when bottles fly from riders in front. There was one bridge we use to cross in a race and it looked like Cape Canaveral!
If it is an A race then always felt new tires and tubes is the best way to avoid flats during a race. Any cut or issue will pop up. If B or C race, just roll with it an if you flat just be prepared, stay calm, change the tube, and chalk it up to one of those things that happens every once in a while.
I would not dismount. I think that would be dangerous for those around you.
I miss you "Sports Night"
