I was finally able to ride the course on Saturday. I was able to ride everything but the road behind the speedway as that was closed. Recorded 53.5 miles with 2800 ft. of gain. The road behind the speedway will add some extra distance and climbing to those totals.
More specific details:
The first half of the course will be fast. Road conditions are pretty nice exiting Laconia and getting on 106. The climb out of Laconia (~miles 1.6 - 2.8) is pretty manageable, riding a 1.56 gear ratio it didn't really get steep enough to force me outside of high Z2, low Z3 power. The turn onto N Village Rd in Loudon brings the first section of less than desirable pavement. This road is very bumpy, it's not so much that there are pot holes everywhere as just having lots of cracks perpendicular to the direction of travel that makes it annoying to ride on. This continues for about 2 miles until it turns into S Village Rd at the 129 intersection, in the last quarter mile the road gets a bit more treacherous - be careful here. From there it's smooth sailing until the first major climb.
After the right hand turn onto 140 around mile 35, the road gets steep quickly. Fresh pavement makes the initial climb smooth; currently they are doing construction at the top of the initial climb in front of the elementary school - I'm not sure if this will be completed by race day so the road conditions could be hit or miss there. The climbs up 140 aren't too bad - they're long and a few times the grades eclipse 10% but generally you shouldn't have to get out of the saddle as long as you have something available in the 25 to 28t range on your cassette. Be careful on the descents! From here on out every time the speeds get high the road conditions get worse. Nothing that's unmanageable, but you'll want to have a firm grip on your aerobars so a bump doesn't cause you to lose your grip.
The left hand turn onto middle route signals the last real climb of the day. I found this road to be enjoyable to ride on - the pavement is generally smooth and the views are great. Lots of rolling hills to start out before the climb intensifies roughly 4 miles after the turn. After reaching the top of middle route the only real notes of importance are that Durrell Mountain Rd. has pretty poor pavement conditions - be careful here. The last thing you want is a flat right before a long descent into transition. Finally, you make a right hand turn onto 107 into a steep descent down into Laconia and transition (this is the climb the old Timberman course used to take you up). Again, this high speed descent can be a bit bumpy at times, so hold on for the ride!
Strava activity is here if you're interested:
https://www.strava.com/.../5681184775/overview
