Fermat, on his last Theorem?
Quote:
it is impossible to separate a cube into two cubes, or a fourth power into two fourth powers, or in general, any power higher than the second, into two like powers. I have discovered a truly marvelous proof of this, which this margin is too narrow to contain
Mathematicians generally assume he was trolling everyone though.
damon_rinard wrote:
Hi MTM,
Thank you for paying my salary! ;-) Yes, we expect availability of the Aduro bar to slow delivery of the P5s that come with it. Not 3T's fault though; we finished the bar design well after the frame.
Leaving the dust cap off the headset does mean the upper bearing gets more contaminants on it. Bearings are relatively inexpensive and easy to replace though, so if you're willing to throw a new one in there every now and then (couple years?) then go for it. As an alternative, I've seen listed on ebay a very thin carbon fiber headset top cap. Probably just one or two plies, maybe thinner than 1mm.
Can anyone find a link to that?
Yes, the Enduro GXP adapters are at Cervelo. So please help out your retailer by quoting the part number; I'm pretty sure it's the same in Denmark. :-) Should work great with your friend's GXP power meter.
I'm trying to reduce the white paper's page count now - which mathematician said he was sorry he didn't have time to make his letter shorter...? ;-)
Cheers,
Kat Hunter reports on the San Dimas Stage Race from inside the GC winning team Aeroweenie.com -Compendium of Aero Data and Knowledge Freelance sports & outdoors writer Kathryn Hunter
