Hi Damon
I have an S5 size 54 now and have placed an order for P5 (tentatively size 51). I want to confirm the correct size for me as it seems, from the P5 geometry chart that I should order one size smaller (a 48) frame than my usual rides - granted, I am gunning for a High-V bar. I hope you understand my concern as my S5 is a size 54 and the P5 charts propose a size 48.
I currently own a Storck Aero2is (size 51 with Top Tube length 515) and Trek Speed Concept (Size M with Top Tube length 518) with
1. Pad Reach of 455 for both bikes and
2. Pad Stack of 580 (for Aero2) and 600 (for Trek SC)
3. Both are on steep seat angle settings circa 78-80 degrees - the Trek being more "laid back". I intend to set up the P5 in the forward 79 degrees seat tube angle
4. Saddle Height 72.5cm
Issue is that I would really like to have a High-V bar (I adore the Star Trek Bridge shape!) but the geometry chart shows that the lowest pad stack for a High-V bar on a size 51 frame is 611mm, which is too high for me.
If I go for a size 48 High-V bar then both pad reach and stack are in the correct ball park intersection. However, the effective top tube length on the 79 degrees seat angle setting is now 476mm, way shorter than my current bikes of 515mm to 518mm (although I believe both the Storck and Trek geometries are based on "normal" tape measurements irregardless of seat angle setting).
Two questions if I choose the size 48 based on my current pad reach and stack:-
1. Will my knees hit the High-V bar? Logically, based on the same pad reach I shouldn't but I need to confirm.
2. Are you able to share the stack and reach of the pursuit bar ends themselves (same as arm pad stack/ reach definition but to center of the pursuit bars)? I think there are people with preferences for short/long pursuit bar reach and/or low/flat pursuit bar stack. These figures are good to know as well.
Thanks for your help.
Discoverspeed: Feb 1, 12 18:26
