The ratio of Lantus:Humalog is a bit off in my opinion. It looks like Lantus is being used to lower glucose when it should be used only to cover the liver dumping glucose. a 50:50% or thereabouts is more appropriate. Personally Im on 1:1.5-2 if you count regular as a meal based insulin. Keep on lowering the lantus and add more basal to cover the spikes.
I also presume you are on MDI so consider adding R for protein, just be careful as its a potent dose and can last ~8h so avoid taking 1 meal before training (ie, if you use for lunch and train in the evening you will crash).
Good luck, its a bit of a trial and error and Im still learning after 20y of T1D but its sort of becomes a fun after a while once you can figure out the outcome most of the time ;-)
Vinnie Santana, Multisport Coach
http://www.ironguides.net
* * * Your best is our business.� * * *
