Re: The New Felt IA [larsvanzanten] [ In reply to ]
Wow! That is a great looking bike!
Powered by All Out MultiSport - http://www.aomultisport.com/
Re: The New Felt IA [Jwizzle] [ In reply to ]
That would be even funnier in Sweden, fel=error, wrong. Tell your husband that it actually says 'wrong Felt' and let him draw the conclusions. Or sell it to a Swede. :-)
Re: The New Felt IA [acco] [ In reply to ]
"Felt wrong" would be even worse ;)
That looks great. I like the all black wheels.
Re: The New Felt IA [Ai_1] [ In reply to ]
i want it
alas my bike is only like 2 years old....and the wife wants a new kitchen :(
ugh.....white people problems
larsvanzanten wrote:
Drumroll, please...
Felt IA 14
Flo 60 + DISC
Powertap P1
THAT is awesome! Great looking bike.
Chris Thornham
FLO Cycling
FLO Blog | Facebook | Instagram | Twitter
Jwizzle wrote:
My lucky lucky husband got the IA 10 I have been coveting (after his bike got stolen). We were sitting in the living room last night admiring it, we noticed something funny (can you see it?)
(Did you find it?)
He's riding a FEL bike.
Now my question: would you want a replacement? He has his own opinion, I'm just curious how other bike fanatics would react!
I would be lying if I said I did not run out and check mine to make sure it was not missing the T. That being said unless they knocked the price down to cost then I would ask for a replacement (a vinyl/sign shop could make a T). Even though you know the bike is legit it could hinder his ability to sell it in the future. I know I would think twice. my 2 cents
Re: The New Felt IA - IA 10, 14, 16 [BryanD] [ In reply to ]
For those who still haven't pulled the trigger, I ordered my IA10 today and Felt said they are expecting them in stock late January which means if I get it before February 1 it would be a win. I made sure I didn't order a "fel".
Re: The New Felt IA - IA 10, 14, 16 [IronStork] [ In reply to ]
They also had a 2015 IA3 for 25% off (in-stock) which was tempting but I really wanted DI2 so I stayed the course. But just a heads-up as may be able to get some great discounts on 2015 bikes.
Re: The New Felt IA - IA 10, 14, 16 [ In reply to ]
I just got a call from the courier on his way to deliver my IA14. So it should be waiting for me after work.
Perfect timing!
I'll be off from today until 4th January and my girlfriend has flown home for Christmas so assuming everything's as it should be with the bike, I'll have plenty time to play with my new toy. I'll book a bike fitting for January. I should be able to set it up pretty well myself but I'll get a second opinion. I might even try fabricating a bespoke rear storage container, but past experience tells me I'm more likely to procrastinate about that for a couple of months before doing it ;)
I'm not expecting the Hadron wheelset I'll be putting on it until a few weeks later as they were on backorder so perhaps no photos for a while yet. We've all seen the stock setup already.
Does anyone else have an issue with the rear brake cable rubbing the stem? I cannot see a way this wouldn't rub based on the shape of the top cap and where the cable is routed.
After a few rides I can already feel the cable housing is starting to wear on the outside. Whats the best way to fix this?
Re: The New Felt IA [Canadian] [ In reply to ]
Drumroll, please...
Felt IA 14
Flo 60 + DISC
Powertap P1
Sweet looking bike. The yellow against the black will make it stick out for sure.
Re: The New Felt IA - IA 10, 14, 16 [The Sloth] [ In reply to ]
Take it back to your shop. It should be routed like this.
Check out my photos a few pages ago. Mine was routed the exact same way. Going to ask for it to be re-routed when I take it in for a service at the start of next year. Where did you get yours from?
Re: The New Felt IA [SuperDave] [ In reply to ]
SuperDave wrote:
aahydraa wrote:
This. Or a Magura front, although the rear mount won''t handle one.
You can run a Magura hydro rear caliper brake on Shimano Direct Mount rear brake mounting standard with an adapter. I recommend the 10 degree tilt version.
-SD
Can someone explain this? Provide a pic or link to the adapter. Is the 10 degree tilt the adapter or type of brake?
 That does not look even close to being right. For a cleaner set up I have no cables going into the calpac
Re: The New Felt IA - IA 10, 14, 16 [seeyouincourt] [ In reply to ]
Can you post a pic of your setup?
Re: The New Felt IA [The Sloth] [ In reply to ]
The Sloth wrote:
BryanD wrote:
This might work
Where can you buy this?
Check this out. A new larger GU Pack for long course racing
http://www.trisports.com/...gel-15-servings.html
Maybe this will fit into the IA box?
Post deleted by seeyouincourt [ In reply to ]
So far I am loving my IA10.
One thing that bothers me a little is there is no quick release for the 105 direct mount rear brake. It has a barrel adjuster by the stem, but that won't be as convenient for quick wheel changes as an actual quick release.
Has anyone tried installing an inline quick release like a Shimano SM-CB-90? Or are there other options?
Can you fit two bottles on the bike frame?
Re: The New Felt IA - IA 10, 14, 16 [Mcluvin22] [ In reply to ]
The IA 10 and 14 have seat tube and down tube bolts so yes, you can fit 2 bottles on the frame
I'm still deciding what kind of hydration setup I want to use. For now I've been training with 2 bottles on the frame.
It might depend on the size of the frame, the type of cages and the size of the bottles.
On my size 54 I can fit 2 bottles using the 2 bolts closest to the head tube on the downtube for the second cage. I cant use a bottle thats too tall in the downtube cage. My 22oz purist bottles fit, but there is not much extra room. My 26oz bottles won't work with a normal bottle cage. The 26oz bottles might fit with a side loading cage, but i'm not sure.
TriSports has the GU flask that you were asking about
http://www.trisports.com/...nergy-gel-flask.html
