oldgoldtri wrote:
Would that still keep me on a 56? I anticipated you might recommend a 54 after the reach shortened up.
Thanks again.
A 54 would work as well (it has a reach at the same point of 411) and would need 4 cm of armpad pedestals. This is where bike sizing gets really tricky, especially if you are completely reliant on fit coordinates without being able to examine the rider's actual position and morphology.
If I assume your fit is spot on and won't need to get any lower, the larger frame is faster than the smaller frame (at least in the case of the IA). But knowing you are extremely narrow, there is cause to think your fit may not be ideal and a 54 certainly provides more room for adjustment.
It is possible that you are on the extreme end of narrow/tall, and that your fit coordinates are spot on. But without photo or video evidence, it's reasonable to be skeptical.
Trent Nix
Owned and operated Tri Shop
F.I.S.T. Advanced Certified Fitter | Retul Master Certified Fitter (back when those were things)
