The Diamondback Serios of Matt Russell
Here we go
https://www.slowtwitch.com/...tt_Russell_6890.html
Re: The Diamondback Serios of Matt Russell [Herbert] [ In reply to ]
Herbert
Do you know why the fairings / covers were off both TriRig brakes?
Re: The Diamondback Serios of Matt Russell [SBRinSD] [ In reply to ]
I expect it was off the front brake so the bottle could be closer to the head tube.
Weekly Vlog | Blog | Skechers Performance | TriSplits | Dare2Tri Wetsuits | Saris
Re: The Diamondback Serios of Matt Russell [Daniel Clarke] [ In reply to ]
Yeah, makes more sense when I look at the close up. The bottle is in real tight.
I still wonder what the the thoughts are on the rear brake.
So MR is not riding an Andean? Thought he had switched.
Re: The Diamondback Serios of Matt Russell [Yeti racer] [ In reply to ]
He crashed his Andean in Kona and they are still holding it. He just now got a new one
Looks like a lot of weight on the front end if two bottles are full. I know others do it, but I would be cautious about it.
Team Zoot/Canyon So Cal
Re: The Diamondback Serios of Matt Russell [Karl] [ In reply to ]
How much of a weight difference does it make when you're leaning your body down over the front end and putting your weight on the bars?
Correct!
http://www.MattRussellTri.com -Pro Triathlete -Tri Coach
Sponsored by: Skechers | Diamondback | FitPro | Knight Wheels 20% off wheels use code: GOMATTRUSSELL!
Re: The Diamondback Serios of Matt Russell [MattRussellTri] [ In reply to ]
If you were going to be getting/switching back to an Andean, why not wait to take that to the wind tunnel instead?
Re: The Diamondback Serios of Matt Russell [gmh39] [ In reply to ]
That was the plan. To go to the tunnel to test both the Andean and Serios. Diamondback sent out a demo bike (Andean) for me just to test in the wind tunnel. Unfortunately the Andean arrived the day I drove to the wind tunnel. If my fitter was not at A2, I would most likely not have went. The time was booked for the wind tunnel and I haven’t seen my fitter (Paraic from Cyclologic) in a while so it made sense since 85% of the drag is the body/position. We made some miner adjustments to my fit that were beneficial in both comfort and aerodynamics. I would consider it a successful trip to the A2 considering I saved 14-19 watts from 0-10 yaw.
I think the bottom one must have fallen on in a race. I might have hit a bad bump and maybe it didn’t hold? It’s held on with some strong magnets but if dirt gets in there, it might weaken the hold.
Re: The Diamondback Serios of Matt Russell [alexer03] [ In reply to ]
I’ve never had any issues with it or heard of people having issues with it. If the bottles are full it might add an extra 3.5 pounds.
Thanks, that's kinda what I figured.
hi Matt
first - thanks for coming on here. the bike is cool but having an athlete post makes it infinitely cooler.
next - that's an interesting crank set up;
165mm ... with a 56 tooth outer ring
can you talk about how you came to those fittings and / or that combo?
and what's the inner ring?
cheers
Dave
Re: The Diamondback Serios of Matt Russell [dsmallwood] [ In reply to ]
My fitter Paraic has set me up with the 165mm crank length. We made the change at the end of 2012. In theory, it should open up the hip angle just a little bit more. Allowing to have a better run off the bike.
I think it’s funny when people are so surprised when I’m riding a 56/42 chain ring. They think that’s so big but almost all of the top 15 women in Kona are riding a 55 chainring. The women are 40-50 pounds lighter than me. A 55 chainring for a woman who is 120 pounds would be equivent to a 58 chainring for a guy who’s 160-170 pounds. This is just a guess. I actually rode a 1x 58 chainring for Texas 70.3 @ IMTX. No hills and with a big 20+ mph tailwind at TX 70.3, I’m glad I had the 58 chainring. I race with low cadence around 75ish without a big torque. I know people have different philosophies about cadence but this is what feels comfortable for ME as I’m more of a strength rider/runner.
Thanks for sharing. As a fellow Serios rider, I appreciate seeing other setup options. Regarding the Speedfil bottle up front, is that just held in place with zip tie(s) around the DB stem?
Have you had a chance to see the new stem (Dan previewed it here on his Andean).?
Team Wattie Ink
Thanks Matt !!!
