kileyay wrote:
I guess I have to concede round 1...
Tom A. wrote:
"Grams of drag" is not only a misuse of units (drag is measured in force, not mass), but it requires additional information (such as test air speed and air density)...and then most consumers of the data will STILL need to "translate" it into some other meaningful unit or speed for context. Yes, Kiley said "at 30 mph", but many times I've seen that key info not be related upon repetition/other distribution, plus it adds to
the confusion of "but I don't ride that fast", etc. steavej wrote:
So the rule of thumb is valid if you are riding at 30 mph. How does one get that rule of thumb converted to say 24 or 25 mph?
I just "calls 'em as I sees 'em" ;-)
Yeah, some of the problems with using "grams of drag" as a reporting value are that most either don't ALSO include the explanations of "when measured at 30 mph" for the grams value, and also "when traveling at a wide range of race speeds" for the roughly equivalent watts and secs/km translations...or, if they are included, people don't see them or understand them, or just simply forget or ignore them...which invariably leads to the question like Stevej made. I've seen it happen too many times to count.
Not to mention that the original ROT used 0.1 lbs as the drag force value, and using 50g as the equivalent introduces an additional ~10% error (since 0.1 lbs is actually 45.5g)
I understand the desire to "simplify" the results for a wider audience, but after observing this a bunch, I don't think grams of drag is the best way to do that. It adds more confusion and uncertainty than it takes away.
IMHO, Specialized is doing it the most "right"...publish the drag chart in CdA (perhaps include the simple explanation that 0.01 of CdA ~= 10W ~= 1s/km) and then report an overall, yaw- weighted predicted time savings over 40K. Boom. Done.
