stevej wrote:
Tom A. wrote:
kileyay wrote:
stevej wrote:
What is going to be your y-axis on the charts?
Good question that I thought a lot about. Grams of drag at 30 mph. There are pluses and minuses to this, but ultimately this needs to be a report that most people understand, and I think those units better lend themselves to comprehension than CdA or CdX
Boo!
What would you want on the y axis? CdA? I've thought about this a bunch of times and I can't think of a significant benefit over the other. What am I missing?
Yes. Because it's the one unit that doesn't require additional test information to be useful.
"Grams of drag" is not only a misuse of units (drag is measured in force, not mass), but it requires additional information (such as test air speed and air density)...and then most consumers of the data will STILL need to "translate" it into some other meaningful unit or speed for context. Yes, Kiley said "at 30 mph", but many times I've seen that key info not be related upon repetition/other distribution, plus it adds to the confusion of "but I don't ride that fast", etc. Edit: And then there's the problem of manufacturers deciding to test at lower tunnel speeds (ostensibly to be more "realistic", but really to show low gram values) and then not being overly diligent about pointing out that speed difference. It just all adds to confusion.
Yeah "grams of drag" has been the most common units used in reporting this type of data, but that's no reason for continuing its use if there's a better and more clear alternative. All of the above is why Specialized has switched to showing their drag charts in CdA.
Or...you can just report the CdA and allow the user to directly "translate" it into their conditions of interest. Plug in your air speed and density of interest and go. Least steps and chance for misunderstanding.
