knighty76 wrote:
BryanD wrote:
I'm perfectly fine with their test.
Bryan I don't want to give you too much of a hard time because a lot of what you say makes sense, and you contributed massively to this test and the following discussion.
But are you really fine with THIS? Gels taped up into the air on a bike that has both an integrated bento AND an integrated draft box, and then 3x 750ml bottles. In the absence of a white paper to justify the protocol it just looks like handicapping. I think this is the kind of thing that has some of the more critical thinkers on here rubbed up the wrong way.
I was only there to bring the P5-X and take photos and video of the testing. I helped Kiley install tires and tubes and that was about it.
Yes, I am fine with it and I will tell you why.
I asked Cervelo why they had those gels taped like that. Their answer was the bikes needed to carry a flat kit of 1 tube, 2 co2, 2 tire levers, and an inflator. 3 bottles were to be carried on each bike and 8 gels.
Correct me if I am wrong, but I don't think you can fit 8 GUs in any of those bentos without the sides bulging out. The P5-X bento is MASSIVE. You take out the tab in the bottom and it goes down into the frame. That is why there is no gels taped on the P5-X. I can almost fit my Iphone 7 Plus into that bento. Cervelo put 4 gels in each bento and taped 4 more on the bikes. On Slowtwitch, everyone is pissed about that. In the real world, this is what you see. If you don't, then you haven't spent enough time around age groupers or walked around in transition.
This was Cervelo's protocol that every bike had to carry the same amount of stuff. So they figured out how to do it and that was taping 4 GUs onto the stems. You can call it handicapping if you want but you are ignoring the reality that these bikes were setup for an Ironman distance race for the average age grouper.
Everyone is ignoring that the P5-X is 3W faster with this setup because apparently aerodynamics is the most important. No, it's not. Not anymore. The bikes are so close to each other that storage and integration is the new Aero.
Take time to reflect on why they set these bikes up, examine the average age grouper, and realize this was all set up for Ironman distance racing and you will see why Cervelo did what they did.
Where are you going to put 8 gels on these bikes?
Make Inside Out Sports your next online tri shop!
http://www.insideoutsports.com/
