jaretj wrote:
I was referring to the angle of the head tube and fork rake and not stack and reach
Edit: stack and reach is about sizing where head tube angles and fork rake is about handling
But there isn't really a "road" offset/angle and a "tri" offset/angle. There have been quite a few tri/TT bikes with trail in the mid to high 50s, and plenty of road bikes with trail in the low 60s. My current road bike has 61mm of trail, my tri bike has 60mm. A few years ago, a 54cm Cannondale Synapse had higher trail than a 54cm Cervelo P2. What makes a tri bike a tri bike isn't just the trail, its everything else as well: a geometry that allows for a good aero position, and a geometry that properly distributes the rider's weight when in that position. The longer reach, which is a major factor in the fit aspect, also contributes to the weight distribution, because it dictates a longer front-center (although I guess one could argue about which is the chicken or the egg).
On my current bikes, the bike with the lower trail and shorter wheelbase (tri) is also the more stable bike. If I were to set up my road bike so that the fit was identical to my tri bike, it would be even less stable. And if I set up the tri bike to match my road position, the handling would be really poor. If you're only looking at trail, you'd think the opposite...
"I'm thinking of a number between 1 and 10, and I don't know why!"
