Syntace SL Replacement Bolts?
I don't think I ever met a bolt I couldn't strip...where do you get replacement bolts? I tried the Syntace website but since I don't read German....
I'd like to keep a few in stock for my aerobar clamp bolts, elbow pad bolts, etc.
Is there a source for bolts or do you all just go to Home Depot and try to find a good match?
Thanks!
Re: Syntace SL Replacement Bolts? [Kido99] [ In reply to ]
If that's a standard 6mm bolt, check with your LBS. Also, I see them advertised all the time on Ebay. Buy some extras and if you buy titanium be sure to put some anti-seize compound on them if they are going into a piece of aluminum. (Or at least some grease until you get the anti-seize compound.)
-Robert
"How wonderful it is that nobody need wait a single moment before starting to improve the world." ~Anne Frank
At $2 a gram, these have got to make you go faster.
Re: Syntace SL Replacement Bolts? [efernand] [ In reply to ]
Yeah - I saw those! When I get to the point where I worry more about shaving grams then strengthening these weak legs of mine I'll think about it!
