mfrota wrote:
Hey guys,
I'm travelling to Orlando, FL (more precisely Metrowest area) and I'd like to keep up with my swim sessions. Any suggestions on pools/masters etc?
If you are in Metrowest:
1. You are kind of in the hood. Not quite but you're close. Be cognizant of your surroundings. It goes from nice to not nice real quick if you head north or if you're in the wrong area on Kirkman
2. You are about ten minutes away from Lucky's Lake. I'd check that out. Otherwise you next closest pool will be the LA Fitness at Kirkman and Conroy (25yd). There's also a YMCA in Dr. Phillips at the corner of Dr. Phillips and Wallace (25yd pool). Two lights past Lucky's and then make a right. Best case scenario you're 15 minutes away from the YMCA Aquatic Center (and that's 45 minutes+ with traffic). Best case scenario you are about 20 minutes from the NTC (double that with traffic).
