Trev wrote:
asianzone wrote:
Trev wrote:
7401southwick wrote:
Ok this is a little gross. How often do you do laundry after a workout? I’ll probably go 4-5 days so the closet gets a little ripe.
Any thoughts / suggestions?
Do you mean you wash worn clothes every 4 or 5 says or you wear the same for 4 or 5 days?
I sincerely hope he meant a wash after 4-5 days and not wear the same for 4 or 5 days? I pretty much chuck my gear into the laundry basket the moment i finish each work out. Exception is cycling bib, i might air it and use it again if it was a short work out
If you throw wet sweaty clothes into a confined space, where they don't dry out and fester they will stink. Then if you wash them at low temperature below 40 degrees, bacteria will not be killed and you end up with clothes which smell.
Scum who market and sell washing powder, concentrated liquid or gel tablet whatever latest marketing shit they invent will tell you otherwise.
Maybe, i don't dispute your theory above
All my run stuff are lululemon (anti stink fabric), they really do not stink, i hand wash all of them usually after each work out and don;t even use a detergent. Never have a problem with smell
What i do throw into a "confined space" is bike jersey and they don;t smell too after a wash, at least i don't have that problem
