Fat Pelican wrote:
Anyone have a good strength routine they can share that has helped them? I need to decrease number of injuries I subject myself to and strength training seem like a good option. Latest injury was strained lateral muscle group and runners kneed, down 3 weeks.
I've looked at all of the top Google hits for this and they are all over the place as far as recommended exercises. Some are mostly upper body, some are mostly plyo, some are just too silly to try in a gym, etc.
Could also do running drills I suppose, not sure if that would be as effective.
So, what works for you?
I'm primarily a runner who dips into the other tri sports during the offseason or when injured, and have been a coach for over a decade. This is just to lay out that I at least have a little knowledge. Here's my 2 cents.
Ignore most of what is out there, it's ineffective except for people who have very particular imbalances that need to be worked out.
A very simple, yet very effective, routine to ensure you're strong and balanced for running is to follow a slightly altered version of Rippetoe's starting strength novice program. Here's how I would lay it out, and please note that I am very conservative in how I'd approach this for almost all runners.
1) His program is three times a week, this one is 2
2) Start this when you're only doing general training, not during a build for a specific race. Your running will suffer for the first 4-6 weeks or more due to adding some serious stress. Don't worry, after about a month your hips and legs will feel STRONG.
3) The only exercises you need are deep squats, deadlifts, shoulder press, bench press and rows. You can look up good for on google.
4) One day 1 each week you squat, deadlift and shoulder press. On Day 2 you squat, row and bench press. For everything you do 3 sets of 5 and heavy as you can to do all 3 sets. Deadlift is only 1 set of 5.
5) Add 5 pounds to each during each session until you can't add it anymore, then add in either smaller increments if possible or only add when you feel strong enough to.
6) The first day you go, be conservative, start with just the bar and then work up. I like to think of it as I'd do maybe 75% of what I think I can do on all of them. You'll quickly increase each week.
7) This is with barbells, no machines.
I do this and have prescribed it to others. The goal is not to squat 500. Most marathoners top out around body weight. But doing it will barbells will require you to recruit all the muscles in your hips and core and you will just get stronger generally. As you do more, you'll notice that you'll get less niggles like runners knee (which is often caused by the knee being pulled by imbalanced muscles) and hills will be easier. This will likely have a beneficial effect on you cycling too.
Give it a try, it's not easy, but it will make you a better and more healthy runner, and it's way simpler than all the other stuff you see out there. And you can rest assured that "lifting heavy" won't make you a worse runner, Alberto has his athletes doing it. It's awesome seeing video of little Jordan Hasay throwing weight around.
5)
