I want to move my aero bars lower (Syntace C2's) but leave my base bar at the same height, my stem is flat (90 degrees) so flipping it would do nothing. I have moved 2 of the 3, 1cm spacers above the stem (previously all 3 were below the stem.) Is this safe? P.S. I dont want to cut the fork just yet as Im not 100% sure if Ill be comfortable with the lowered bars. P.P.S. I also rotated the base bar so as to move the "hoods" up and rotated the aero bars down.
Re: Stem spacers above stem [74]
It's safe, just doesn't look as cool. A number of pro mechanics in europe still put a spacer above, apparently they feel the carbon steerers are less likely to crack that way.
Moving spacers on the steerer WILL move he base bar. The only way to change your aero position without moving the base bar is to change the distance between the elbow pads and the base bar. Often this requires a different clip-on (not all of them have adjustment built in).
Some are born to move the world to live their fantasies...
https://triomultisport.com/
http://www.mjolnircycles.com/
I personally think it's a good idea to have a spacer or two above the stem. You never know when you might want your bars higher. When setting my bike up for many months to come of late-night trainer rides, I was glad I had the extra height. I flipped my stem up and moved it as high as it would go so that the bars are at a nice high and comfortable height. No need to be so aero on the trainer.
I keep two spacers above the stem. You never know when you need a higher position. I have seen as many as five (in a magazine article illustration), but I think this was because the rider using this bike and was to send it back.
1 to 2cm above and any more makes it a 'bagel holder!'
If there is a plug meant to reinforce the clamped area of the steerer where the stem attaches then there is a risk of crushing the steerer tube. You should NEVER have more than 90mm of exposed steerer above the top of the headset.
Measure twice, cut once.
SD
https://www.kickstarter.com/...bike-for-the-new-era
SD
