My possible future training partner and I are having a debate over the best long term minset to training. I say, learn to spin and keep heart rate low over long distances while including an occasion interval workout after a base is established. Bonehead says mash as far and as fast as possible to form your base and to get to the level you are desiring. Please help.
Re: Spin vs. Mash [NuNOLATri]
Bonehead is wrong, and so are you. Get a decent book on endurance training so you know why you are doing what you are doing. You'll stay slow, and so will he. He will get burned out and miss workouts and possibly overtrain. You will just be slow and stay that way. Both are not so good (although, if I had to choose, I'd avoid burnout and overtraining).
Read Running With Lydiard. While it is a running book, everything in there translates to cycling. You'll get a clear understanding of why a base is important -- and also a reminder that base-building is not "easy". Done right, it is some tough work that takes 15-20 weeks to accomplish.
Then get The Cyclists Training Bible to put your now fluent understanding of why you need a base to actual productive work.
Also read the articles on AeT training over at gordoworld.com on the Tips page.
Easy spinning will build a weak base. Hard hammering will build no base. There is a "between range" that you need to learn about. Lydiard discovered it in the 1960's, and Friel has a good handle on it in his Bible series.
Post deleted by jaretj
I can't thank you enough for you assistance. I guess that old saying about "when all else fails read the directions" holds true again.
