ogni wrote:
Hi, i have a VIAS and the two Specialized specifique Aero bars. Unfortunately they are very low and i would like to have them a bit higher. Specialized does not have a riser kit and therefore i’m looking for a solution or idea how to solve this issue.
Thanks
My understanding is that you already have the "Vias Aerofly FLAT" and "Vias Aerofly with 25mm riser" (shown in the link above) but even with that 25mm riser bar you want more spacers.
Did you buy this bike used? I'm guessing you bought it from someone who already removed all of the headset spacers and cut the fork. If that's the case the only way to add stack is the get a new fork that hasn't been cut down, unfortunately.
The vias stem doesn't allow for any spacers to be stacked above it, so removing spacers is permanent.
Another possibility is to get a shorter stem which will decrease your reach and may feel much better. I have a brand new 95mm Vias (s-works) stem that will work if you're interested. Shoot me a PM if so.
