Looks good. New to you bike, or new new bike?
Re: Specialized Transition mafia [cvcabran]
Re: Specialized Transition mafia [littlefoot]
New to me in 2012. Below are the specs when I finished it earlier this year. It's been a great bike, but I recently got a Shiv Di2 and am currently parting out the Transition. (See Classifieds!)
2009 Specialized Shiv Pro
Basebar: Zipp Vuka Bull, carbon, 0mm drop, 42cm width
Extensions: Zipp Vuka Race Shift, carbon, with integrated R2C bosses
Shifters: Zipp R2C
Shift Levers: Zipp Carbon Levers
Brakeset: Specialized Integrated Brakes
Front Derailleur: Sram Red with K-Edge Chain Catcher
Rear Derailleur: Sram Red
Crankset: Sram Red, 50x34, 165mm
Rear Cassette: 10 speed 11-28
Saddle: Specialized Romin Evo
Wheelset: 2008 Zipp 404 Clinchers with Powertap SL+ 2.4 Ant
Skewers: Zipp
Tires: Continental GP4000S
Tubes: Q-Tubes 80mm long valves
Shifters: Zipp R2C
Skewers: Zipp
Very nice... Was it easy to replace the crankset from specialized to SRAM?
Anyone used stages PM for Spez-Tranz? I was thinking of getting one where I can swap it between bikes but the different BB might be an issue. Road bike uses hollowtech 2 and spez tranz seems to be proprietary BB...
Re: Specialized Transition mafia [cabdoctor]
Did you ever finish this? Can you post pics. I am curious to see the final outcome.
Thanks.
What brand paint did you use?
Thanks.
cabdoctor wrote:
yimmy wrote:
Project is finally coming together. Painted matte black and awaiting decals. What brand paint did you use?
Re: Specialized Transition mafia [helios]
Out on my trusty TT today, nearly 5 years and still going strong :-)
http://twitter.com/willrc91 --- instragram.com/willrc91
Re: Specialized Transition mafia [gregtay]
gregtay wrote:
So has anyone successfully installed the internal di battery somewhere inside the Transition frame? Looking to swap over to di but still stuck on what to do with the battery.... want everything to be internal.I did. Seat tube. Drilled the hole through bottom bracket (using the hole for rear brake hanger) and routed the cable throught the power tap hole to the exit on top tube (where 4 exists are located).
Re: Specialized Transition mafia [deadliner]
Battery is perfect fit in the seatpin, theres a rib inside the pin and i drilled a small hole through it and put a zip tie through it to stop the battery sliding out
Re: Specialized Transition mafia [neilridley]
Hey all I see this forum isn't overly active but still alive. I'm a new roof me owner of 2012 Trans Comp, had a bike to small so traded someone for this bike and cash. Ordered a Force carbon crank, Force front and rear derailleurs and already had a full carbon cockpit. Should be putting it all together this weekend and will post some pics once done!
- There are some who call me... Tim
"It's not how far you go, it's how go you far" - Dave Marshak
My Blog - http://www.260totri.com
Re: Specialized Transition mafia [Diablo243]
Anyone have a Specialized Virtue bottle and cage for sale?
I've got a bottle/cage that is not being used. The bottle has a certain "je ne sais quoi" scent, likely from not being used in a few years... PM me if interested as we cannot break any rules here with buy/sell in this forum...
Re: Specialized Transition mafia [legalgooner]
Pm sent, thanks!
Diablo243 wrote:
Anyone have a Specialized Virtue bottle and cage for sale?if you can read this
YOU'RE DRAFTING!
Re: Specialized Transition mafia [flogazo]
Hi Guys,
Anyone have the problem where the outer front derailleur housing got pulled into the frame at the top of the top tube, any idea how to get it out ?
Thanks in Advance
Casso
Thanks in Advance
Casso
Re: Specialized Transition mafia [gickna]
Hi!
I guess this is a good place to ask: What is the tire clearance on 2010/2011 transition? Enough to fit 25mm tires on wide rims? (Zipps rims are 24mm, Dura Ace WH-9000-C50 are 23mm wide)
Re: Specialized Transition mafia [lazybiker]
I run 25s on my 2010 comp with no issues.
I had issues with 25's. I don't remember what rim it was though sorry but that's when I made the move to 23's on all my bikes as I swap wheels a lot
Thx Diablo! I've been offered a nice deal on 2010 transition pro w/o wheels, so just wanted to make sure.
Re: Specialized Transition mafia [vancity]
vancity wrote:
I had issues with 25's. I don't remember what rim it was though sorry but that's when I made the move to 23's on all my bikes as I swap wheels a lotI spoke with the owner earlier today and he told me he had no problems with ZIPP 303's (which are very wide)
lazybiker wrote:
Hi! I guess this is a good place to ask: What is the tire clearance on 2010/2011 transition? Enough to fit 25mm tires on wide rims? (Zipps rims are 24mm, Dura Ace WH-9000-C50 are 23mm wide)
I just purchased a 2011 pro for TT's and used a HED + rim with 25mm tires on the rear, it was very close but fine. I also used a Zipp 808 with a 25mm tire and again had no issues, but the brakes were opened up all the way and the screws in the dropouts had to be adjusted to get the tire to clear the wheel cutout. A 25mm tire would be the absolute max on a newer wide rimmed wheel though as it measures just over 25mm in actuality.
Re: Specialized Transition mafia [Ron_Burgundy]
As a side note has anybody gone to a tri rig front brake to get rid of the 1cm spacer that is used to hold the brake cable? I need that 1cm to get into my ideal position. Right now i am using a -35 stem to get into a close to ideal position.
I'm in the process of doing this.
Not to lose that one spacer, just b/c the front brake is coming to end of life.
Omega SV
But, make a note of this....the instructional video has us just sliding the omega sv onto 2 posts coming out of the fork.
don't know about you guys, but my fork on my 2011 Transition has threaded ports rather than posts. There are some posts that are sold by Specialized and TRP (I think) that need to be threaded in before omega sv front brake can be loaded onto the frame.
Just fyi in case you go this route.
"Outwork your talent." Kevin McHale
Omega SV
Re: Specialized Transition mafia [morpheus]
Never posted my Transition. 2010 Specialized Transition Pro with Rotor Q rings and Rotor Aero crankset. Pictured with Zipp 900 Clincher disc wheel and Zipp 1080 front.
“Pain is temporary. It may last a minute, or an hour, or a day, or a year, but eventually it will subside and something else will take its place. If I quit, however, it lasts forever.” - Lance Armstrong
Re: Specialized Transition mafia [cyclinglawyer]
can anyone riding a medium transition (perhaps even specifically a 2011) give me an idea of your height/inseam?
looking at one posted in the classifieds and trying to get an idea of whether or not this could be a good fit for me
thanks!
thanks!
2010 S Works here...inseam is ~31" and I'm fine. I have both a straight seatpost and a team setback post and have measured effective TT length as short as 47cm and as long as 56.5cm.
I have ~11cm of drop from center seat to arm pads.
