Hello, I recently did spring maintenance on my Felt Z5 road and Specialized Shiv Comp tri bike. Got out for a ride and noticed the Shiv has about 1mm of "slop" or "play" in the upper bearing. I took the handlebars off and upper spacers and think I need to press the upper bearing compression ring down a bit more to seat the ring and bearing into the cup, then reassemble and torque things down. I did preload the bearings by tightening the top Allen bolt over the cap. Looking at the pic you can see the compression ring is sticking up a bit. This was my 1st time working on the Shiv and didn't want to tap on it or force it (the bearing compression ring) until I had some feedback. When I hit an expansion crack riding on the trail the headset "clunked" a bit. ANY advice greatly appreciated.
Thank you!
Tom
Thank you!
Tom
