I am currently in the process of building up a Specialized Shiv, but I'm not sure what size bottom bracket the Shiv uses. Does anybody know what size bottom bracket the non S-Works Shiv uses because I read that they don't have the same size bottom bracket.
Re: Specialized Shiv Bottom Bracket [Charleslo_99]
Still BB30 to the best of my knowledge. Specialized hasn't done anything different for years, other than move away from the PF30 standard and put real cups in the frame.
Re: Specialized Shiv Bottom Bracket [grumpier.mike]
I heard too it's BB30, overheard from a guy from a local meet up who got Specialized Shiv bottom bracket.
I had one and was a BB30
If you're talking Shiv TRI, my 2013 is BB30. Non-Sworks.
I wanna go fast!
I wanna go fast!
Re: Specialized Shiv Bottom Bracket [ironmanatee]
its BB30 but I would look into something like this https://www.merlincycles.com/...d9gazsAaAvu9EALw_wcB
although it depends on the build... on my last build I went this way due to my original BB30 shiv bearing somehow wallowing itself out....
ironmanatee wrote:
If you're talking Shiv TRI, my 2013 is BB30. Non-Sworks.Technically I believe it's OSBB which is almost the same, but not exactly the same as BB30.
If the OP is looking to run other than Specialized S-Works cranks he needs either a set of press in adapters for his cranks or a whole new BB.
For example, for SRAM cranks.
https://wheelsmfg.com/pressfit-30-to-outboard-bottom-bracket-for-24-22mm-cranks-sram-w-angular-contact-bearings-red.html
Note from that page: * Specialized Carbon OSBB with 61mm shell width will need additional 3.5mm cup spacers.
That is compared to a standard BB30/PF30 bottom bracket shell
For Shimano:
https://wheelsmfg.com/pressfit-30-to-outboard-bottom-bracket-for-24mm-cranks-shimano-red.html
Kevin
http://kevinmetcalfe.dreamhosters.com
My Strava
I'm >98% sure they are all BB30/OSBB (specialized term for BB30). Regardless of S-works or not S-works frame. The differences there are, I believe, BB shell material (carbon vs alloy insert) and bearings (ceramic vs steel) that come with the framesets/bikes.
Re: Specialized Shiv Bottom Bracket [albertsonrm1]
Great to know!
Re: Specialized Shiv Bottom Bracket [cantbeataktm]
Thanks, for all your help. My local S-Works dealers also confirmed it is a BB30 Bottom Bracket as well.
Hi! I am going to hijack this thread for some information - does anyone know what type of bottom bracket a 2016 S-Works Shiv would have? I am looking to swap the crankset and want to confirm which parts I will need.
Re: Specialized Shiv Bottom Bracket [kerikstri]
kerikstri wrote:
Hi! I am going to hijack this thread for some information - does anyone know what type of bottom bracket a 2016 S-Works Shiv would have? I am looking to swap the crankset and want to confirm which parts I will need.What type of crank do you have? What are you going to?
Maurice
I would guess that your frame is BB30.
Have you looked at the bottom bracket?
Re: Specialized Shiv Bottom Bracket [mauricemaher]
I have a S-Works carbon crank right now, but it has a 110 BCD so I am limited for stock chainrings (I have a 52/36). I want to get a crank that has a 130 BCD so I can put a larger set of TT chainrings (probably 54/42 or 55/42). So I guess my real question is what crank should I be looking at getting (that has a 130 BCD and will fit my frame)?
What type of bottom bracket shell does your frame have?
Re: Specialized Shiv Bottom Bracket [jimatbeyond]
I tried looking on the frame, but it doesn't really say by the bottom bracket. It just says ceramic speed (no size/description).
Is there a bottom bracket (bearings) installed in the frame?
