Slowtwitch Indoors - Group Workout Series on Zwift
Apr 10: 70.3 Ramps
ABOUT THIS WORKOUT
This workout is designed to train your ability to change power and to surge and recover. It makes use of varying duration ramps to lift the power progressively within each block. The warm-up includes some high effort sprint surges to get the legs primed for a workout that is anything but "steady."
The first set is a series of 3 high-effort ramps with aerobic ramp recoveries. 30 seconds building in the anaerobic zone (125->150% FTP) with the recoveries then being 90 second ramps from 70-80% FTP. These high effort surges mimic the early intensity of races where jockeying for position often happens out of the swim.
The main set consists of two rounds of three pairs of ramps. The opening ramp is 1 minute from 100-125% FTP, right at the top end of the aerobic zone. Then the recovery brackets typical 70.3 power - from 80%-90% FTP - over 4min.
All sets have 4min easy spinning between.
ABOUT SLOWTWITCH INDOORS
Every Tuesday at 4pm PST, Slowtwitch.com will bring you a triathlon-focused workout designed and led by a guest 'coach.' We will include sessions from pro athletes and coaches, as well as the Slowman himself, Dan Empfield.
The workouts are about 60 minutes long and designed to add variety and interest to your weekly training schedule over the Winter.
For more workout information, check out: http://forum.slowtwitch.com/...es_on_Zwift_P6533129
ABOUT GROUP WORKOUTS
Zwifters line up in the starting area just like a normal event and once the event starts, workout mode begins. Everyone stays together regardless of power output. That's right, if you're outputting 100W and another Zwifter is outputting 400W you will stay in exactly the same position relative to each other. Only if you stop pedaling and fall 6 meters behind the group will the rubber-banding stop.
HELPFUL HINT
We highly recommend doing one of the FTP tests as the estimated FTP can be inaccurate and make the difficulty level of the workouts too high for your current fitness level.
For more info on FTP go to: https://support.zwift.com/...-is-it-used-in-Zwift
ZWO WORKOUT FILES
All workouts to date: http://slowtwitch.com/...owtwitch_Indoors.zip
Individual workouts:
Twin Peaks - http://slowtwitch.com...Double_Peak.zwo
Twin Peaks (Harder OG Edition) - http://slowtwitch.com...Double_Peak_OG.zwo
5x5min 70.3/IM over-under - http://slowtwitch.com/...oors__5x5min_703.zwo
8x3min progressive 70.3 big gear - http://slowtwitch.com/...s__8x3min_BG_703.zwo
8x4min SST with 2min - http://slowtwitch.com/...8x4min_with_2min.zwo
Herbert's ramps - http://slowtwitch.com/...ors__Herbert_s_R.zwo
Happy Birthday Jesse Thomas - http://slowtwitch.com/...ors__Jesse_Thoma.zwo
Linsey Corbin's SST - http://slowtwitch.com/...insey_Corbin_SST.zwo
Matt Lieto's Over-The-Top Gravel - http://slowtwitch.com/...Lieto_Overthetop.zwo
Penticton Condensed - http://slowtwitch.com/...ors__Penticton_C.zwo
Sub-Threshold - Vo2 (most recent) - http://slowtwitch.com/...ub_threshold_Vo2.zwo
The Slowman Cometh - http://slowtwitch.com/...ors__The_Slowman.zwo
Tri-Roubaix - http://slowtwitch.com/...ors__Tri_Roubaix.zwo
"Non est ad astra mollis e terris via." - Seneca | rappstar.com | FB - Rappstar Racing | IG - @rappstar | Game Designer @ Zwift
Ask me about: 1st Endurance | Normatec - $100 off RAPP2018 | Zipp | Quarq | SRAM
Re: Slowtwitch Indoors - Group Workout Series on Zwift: Starts Tue, Jan. 16th @ 4PM PST [Rappstar] [ In reply to ]
very cool! thanks to everyone involved organizing these.
2018 Schedule: Texas Half Ironman April 8 // Tri Cap Tex, May 28 // Cypress, TX Sprint July 29 // Kemah, TX Olympic October 21
Wouldn't mind trying that but 4pm PST is midnight GMT so the timing isn't going to work for me. Hope it goes well.
Re: Slowtwitch Indoors - Group Workout Series on Zwift: Starts Tue, Jan. 16th @ 4PM PST [Ai_1] [ In reply to ]
Same here ... but what's wrong about sitting on your trainer @ midnight!? ;-)
Re: Slowtwitch Indoors - Group Workout Series on Zwift: Starts Tue, Jan. 16th @ 4PM PST [motorcity] [ In reply to ]
An angry partner waiting in bed and having to get up for work at 6am?!
Other than that, I'd be fine with it!
Awesome, do we get to use the disc wheel? This is slowtwitch after all....
Would your partner typically not sleep by midnight? ;-) But I get the 6am-getting-up-issue. 6am for work or for a workout?!? ;-)
perhaps we could have TWO slowtwitch weekly rides. one for the brits and other people who ride their trainers on the correct side of the road, and the other for weirdos like me. and maybe a third for the aussies, who are none of the above.
Dan Empfield
aka Slowman
Re: Slowtwitch Indoors - Group Workout Series on Zwift: Starts Tue, Jan. 16th @ 4PM PST [Slowman] [ In reply to ]
No matter if left or right or in the middle is the correct side of the road. But I want to make sure that I do not want to be recognized as driving on the left side of the road! ;-)
Well, not sure about others, but typically 7 or 8pm might work for most Europeans, I guess. So, 10 or 11am PST.
motorcity wrote:
No matter if left or right or in the middle is the correct side of the road. But I want to make sure that I do not want to be recognized as driving on the left side of the road! Well, not sure about others, but typically 7 or 8pm might work for most Europeans, I guess. So, 10 or 11am PST.
that i could do. 10am pacific sounds pretty good to me.
Dan Empfield
aka Slowman
But then it's 10am to 1pm everywhere in mainland USA. 99% of us are at work.
Maybe there should be a North American-centric ST ride and a Euro-centric ST ride. Have Jordan/Dan/Whoever captain the N.A. ride and some well known Euro ST'er captain the Euro ride.
2018 Races:
Finland 70.3, Lahti, Finland, June 30th | Jonkoping 70.3, Jonkoping, Sweden, July 8th | Augusta 70.3,
September 23rd
| Waco 70.3, Waco, TX, October 28th | Cartagena 70.3, Cartagena, Colombia December 2nd
Gear: Dimond Bikes | Desoto Sport | Hoka One One
that's 8pm my time. Nice!
I should be able to swing it, but will have to talk it over with my wife to switch my tuesday masters swim night to another night of the week. and actually sign up for zwift....
Swimming Workout of the Day: http://forum.slowtwitch.com/...ost=5784860#5784860;
Favourite Swim Sets: http://forum.slowtwitch.com/...m.cgi?;post=5004659;
Winner of the 2017 50 fly east coast Smackdown. http://forum.slowtwitch.com/...ost=6294538#p6294538
Re: Slowtwitch Indoors - Group Workout Series on Zwift: Starts Tue, Jan. 16th @ 4PM PST [The GMAN] [ In reply to ]
I believe the statement by Dan was:
  • "one for the brits and other people who ride their trainers on the correct side of the road": Brit (and Europeans)
  • "and the other for weirdos like me": US
  • "and maybe a third for the aussies, who are none of the above.": Aussies
Re: Slowtwitch Indoors - Group Workout Series on Zwift: Starts Tue, Jan. 16th @ 4PM PST [Thomas Gerlach] [ In reply to ]
Thomas Gerlach wrote:
I might have to finally join Zwift!! It has been over two years since I tried it at the Kona Slowtwitch party. Very cool. Will all the group rides be no-drop rides?
I ride lots on Zwift but haven't tried the group workouts yet. As I understand it they shelve the normal power based speed physics model and just set a speed for the group so that everyone goes the same speed so long as you keep pedaling. I think you only get dropped if you actually stop pedaling.
6am for work.
We usually go to bed about midnight but I'm up for work between 5:30 and 6:30, it varies. I don't normally do morning training.
Don't forget UK and Ireland are on Western European time (GMT/UTC) while most of Europe such as France, Spain, Germany, Italy, Belgium, Norway, Sweden, Austria, Poland, etc are all on Central European time (UTC+1) and then there are the countires further east that are another hour ahead but let's ignore them ;)
I'm guessing 18:30 to 21:00 local time is the window that will catch most people. I'd certainly have difficulty making anything earlier than 18:30 most days.
I think a start time of 18:30 UTC will accommodate most people for for the Europe targeted ride. That'll be 18:30 in Ireland & UK, 19:30 in Central Europe, and 20:30 in Eastern Europe.
19:00 would be best for me personally but then Eastern Europe is getting late.
Are there any free Zwift codes longer than the 7 days ?
Just a pet peeve, but is there a reason they are not promoting helmet use? I see riders with no helmets and don't feel that's a very smart or healthy way to promote. Maybe the old man in me, but drives me nuts.
Re: Slowtwitch Indoors - Group Workout Series on Zwift: Starts Tue, Jan. 16th @ 4PM PST [ggeiger] [ In reply to ]
I'm not sure I agree with the "not promoting helmet use." Zwift is not real. You can't crash. You do not need a helmet. The idea that somehow by not wearing a helmet in the virtual world that we are somehow encouraging a lack of helmet use just doesn't seem to me to have any actual evidence supporting it.
Reminds me a lot of the discussion about violent video games and real world violence, something where the evidence just isn't very strong in terms of showing correlation or causation: https://www.health.harvard.edu/...mes-and-young-people
Certainly, in my own case, I never wear a helmet in Zwift. But I would never even consider not wearing a helmet outside. And that's true of most of the folks that I know. By which I mean, I do not know a single cyclist who would ride without a helmet outside. But it's pretty mixed in terms of who does and doesn't wear a helmet on their avatar.
Sorry, but can't agree with your opinion. Sets a bad precedent IMO.
Also your article does not say there is no link, and other sources say otherwise, so a bad choice of example.
Precedence for what exactly?
Did you actually read what Jordan said or do you prefer simply regurgitating the same thought independent of helpful commentary that happens to not agree with your own?
Of course it hurts. The trick is not minding it hurts.
Seriously??? It's a damn video game, FFS.
2018 Races:
September 23rd
Chill dude. My opinion, so you could care less. Fine with me. Not my thing anyway but was surprised given the times. Feel the wind through your hair...... :-)
Ha! Speak for yourself! I’ve fallen off the trainer before! I still don’t wear a helmet in Zwift though... it messes up my sweet hair.
